Thread: 97 gtp misfire/shift issue
Results 1 to 15 of 15
  1. #1 97 gtp misfire/shift issue
    Apr 2012
    Philadelphia, pa
    Not sure if this is in the right section but here it goes, I have a 97 gtp with 170k,(91 k motor) plugs have about 3k on them, msd coils and wires, cat delete, cold air intake, new intake manifold gaskets, new fuel pump, new motor mounts. Under hard acceleration the rpm keeps rising and over 3k rpms the car feels like it is misfiring or running against the rev limiter if I let off the gas and hit it again it shifts into the next gear.... Please help!!
    Dec 2010
    DMV
    Any service lights?
    Recent maintenance?
  3. #3 Re: 97 gtp misfire/shift issue
    Apr 2009
    Fort Worth TX
    Just started doing this or after coil install?
    I know people have had trouble with the MSD stuff.
    Dec 2010
    DMV
    I think you just found your problem.
    MSD coils are notorious for causing issues like misfires and other strange things. You have a set of stock coils to see if it's the coils? Why'd you change the coils?
  5. #5 Re: 97 gtp misfire/shift issue
    Apr 2012
    Philadelphia, pa
    I had a oil change about a month ago, mobil 1.. I really don't drive the car much just about 50 miles a week. I changed the coils because I had a bad one and I had a gift card to jegs and figured what the hell I'll give them a shot. The coils have about 500 miles tops on them. No cel lights or anything, this problem just started a few days ago. I love the car but damn every month its always something!!
  6. #6 Re: 97 gtp misfire/shift issue
    Apr 2009
    Fort Worth TX
    I can't believe there is not a P030X DTC. So you actually scanned for codes?
  7. #7 Re: 97 gtp misfire/shift issue
    Apr 2012
    Philadelphia, pa
    The car will actually run right to red line under hard acceleration before it shifts but over 3k just starts running like I dropped it in neutral or something, but if I'm driving like a normal person, which I never do it runs fine...
  8. #8 Re: 97 gtp misfire/shift issue
    Apr 2012
    Philadelphia, pa
    Yea I scanned it the while I drove around and no codes, even the typical cat code didn't come on!
  9. #9 Re: 97 gtp misfire/shift issue
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Wilong View Post
  10. #10 Re: 97 gtp misfire/shift issue
    Switch back to stock coils.
    What plugs are you running, what gaps?
    I hope you are running atleast 91+ octane fuel.
    Dec 2010
    DMV
    Stock coils are the best replacement.
  12. #12 Re: 97 gtp misfire/shift issue
    Apr 2012
    Philadelphia, pa
    Always use 91+ ngk plugs but I don't remember the gap, I put them in about a year ago when I dropped the new/used motor in
  13. #13 Re: 97 gtp misfire/shift issue
    I'll add in my condeming of the coils as well. Swap them, let us know. I'd say 85% that they are the issue.
    They are pretty and red, so they match the color on your face when you are pissed about the misfiring.
  14. #14 Re: 97 gtp misfire/shift issue
    Apr 2012
    Philadelphia, pa
    I'm going to swap them out today, thanks for the suggestions!
  15. #15 Re: 97 gtp misfire/shift issue
    Apr 2009
    Fort Worth TX
    Don't rule out the MSD wires either. Put some AC Delco's or Autolites's on it.
  1. Hard shift issue
    By 7point62 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2012, 08:00 PM
  2. 99 GT 1-2 Shift Issue
    By TeeWX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2011, 06:43 AM
  3. Misfire issue/question
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-13-2011, 11:24 PM
  4. misfire issue
    By SS98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 09:12 PM
  5. misfire issue, out of town and no tools
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 12:18 AM
