Thread: Aftermarket FPR's?
Results 1 to 5 of 5
Guest Aftermarket FPR's? 09-01-2008, 10:21 PM
IndeedSS Re: Aftermarket FPR's? 09-02-2008, 07:48 AM
Smokin2000gtp Re: Aftermarket FPR's? 09-04-2008, 11:46 AM
IndeedSS Re: Aftermarket FPR's? 09-04-2008, 11:53 AM
Street Wolf Re: Aftermarket FPR's? 09-04-2008, 11:54 AM
  1. #1 Aftermarket FPR's?
    TDCRacing
    Guest
    So whats the deal with these? I mean theres not any to my knowledge and im sure theres a good reason. So i wanna know that good reason lol. Im guessing the stock 4or whatever psi is good? The main reason i ask is because of the power level im at.
    I remember someone said one time that there is a stock replacement part...maybe acdelco...that gave them like 6 extra psi.
  2. #2 Re: Aftermarket FPR's?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by TDCRacing View Post
    GP Sorensen is the one people go to. I wished I could tell you the reasoning, but I can't remember. If you go to clubgp, search for Sorensen, filtered by author Mithelen you should find the part number and the reason why it's the preferred FPR.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Aftermarket FPR's?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    GP Sorensen 800-302
    Most of the old GM FPR's I have seen have a 1/16" diameter return hole though them. The GP Sorenson ones have a 1/8" diameter one. If you are using a high volume pump, the small hole regulators can cause pressure to creap up at idle and cruise due to too small of a hole for the fuel to return through. The GP Sorensone ones also tend to be about 2 PSI higher base pressure (arround 54 PSI)than the GM ones (around 52 PSI), which, if you are on the edge of maxing out your injectors will help extend them a little further.
    PRJ
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  4. #4 Re: Aftermarket FPR's?
    St Louis MO
    and there you have it.
    2010 Camaro SS LS3
  5. #5 Re: Aftermarket FPR's?
    Banned
    Wichita Falls, Texas
    Just got myself a GP Sorensen the other day. Don't know why though.
    (Edited becuase someone already posted the parts number. lol)
  1. Aftermarket bushings
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-06-2008, 09:07 PM
  2. 04 Aftermarket hood
    By JCG's-GTP in forum Visual/Body Modifications
    Last Post: 02-26-2008, 11:22 AM
  3. Aftermarket Exhaust
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 12:18 AM
  4. What aftermarket convertor do you run?
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2008, 12:20 PM
