Thread: how do i know if my lower intake manifold gasket is bad?
Results 1 to 19 of 19
  1. #1 Re: how do i know if my lower intake manifold gasket is bad?
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    All this talk about coolant in the oil... I see oil around my LIM and also see oil on my garage floor. I am told the oil is pooling around the bolts and leaking down.. Is that a sign of a broken LIM
  2. #2 Re: how do i know if my lower intake manifold gasket is bad?
    Quote Originally Posted by andremike View Post
    chances are you have a oil leak, (valve covers or oil pressure sensor or oil pan) and your lim bolts are seeping coolant, just like mine have been for 6000 plus miles.
    i have 2 bolt valleys that have coolant in them, and one at the end that coolant runs off the side but steams off before you would know it was there.
    i also have the old plastic gaskets and should change them on general principals but i am letting it go for now.
    i'd address the oil leak first.
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. 3400 ohv lower intake manifold gasket questions
    By Bjorn20 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-13-2012, 07:34 PM
  3. the best lower intake manifold gasket?
    By bps02gtp in forum General Tech Discussion
    Last Post: 06-24-2011, 05:04 PM
  4. Changed lower intake manifold gasket and valve cover gaskets
    By grn97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 08:19 PM
  5. lower intake manifold gasket
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2010, 09:26 PM
