Thread: How to tell if struts are bad?
Results 1 to 18 of 18
  1. #1 How to tell if struts are bad?
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I hit bumps really hard and its beginning to annoy me. Sometimes when im accelerating my car will also bounce up and down like its driving on a trampoline or something. Are these still strut problems? I can't tell what it is. I just know that it rides really rough and whenever i go over big bumps its kinda like my car is falling down the grand canyon. I'm pretty sure this isn't safe either
  2. #2 Re: How to tell if struts are bad?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    sounds like you have bad struts. the only reason i know this is because my friend drives a bonneville and when he goes over speed bumps, the rear end of his car bounces like mad, exactly like a trampoline. He has two bad rear struts. Sounds like you have the same problem, so my guess, bad struts it is
  3. #3 Re: How to tell if struts are bad?
    St. Louis
    And while you're at it replace all the springs too as they are just as worn out.
  4. #4 Re: How to tell if struts are bad?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    springs usually last for life unless there cracked or rusted, shocks which are whats inside the spring is filled with a liquid which over time leaks out ect also the strut topper plate can rust which is dangerous and should be replaced, if your not very handy just buy loaded struts (spring and shock already together) and put them in a car if youve never done that before be sure to ask some one who has it can be very dangerous, if your a bit more handy then just replace the shocks and use your old springs if there still good
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
    Bunnell, FL
    Put the car on jack stands for a few hours and then lower it back down. If the car sits higher now you need new struts
    I'm a Sex Offender
  6. #6 Re: How to tell if struts are bad?
    Oct 2011
    Michigan
    how many miles on the car? usually shocks only last 75k miles but in some places (like here in michigan) your more likely to get 50k out of them
  7. #7 Re: How to tell if struts are bad?
    Jan 2012
    Philadelphia
    Quote Originally Posted by FordMan77 View Post
    if your going to buy stock struts then buy the strut and shock in once no sense putting in stock spring into a stock strut
  8. #8 Re: How to tell if struts are bad?
    Oct 2011
    Michigan
    i was just trying to save the guy some money all new struts can get quite pricey even just OEM replacements
  9. #9 Re: How to tell if struts are bad?
    Jan 2012
    Philadelphia
    Quote Originally Posted by asite57 View Post
    well OEM replacements would cost alot
    but complete struts from an auto parts store not as much
    but i understand what you mean with saving money struts are not that cheap no matter where you get them
    just don't buy used!
  10. #10 Re: How to tell if struts are bad?
    Antioch, IL
    Bounce the car, after you stop it should bounce/move once then stop. If it bounces twice they are going. Anymore and they are done. If you go inside and its still bouncing call a priest.
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: How to tell if struts are bad?
    Jan 2012
    Philadelphia
    if it feels like a trampoline when you hit a bump there bad enough said, replace them. should be fine to drive like that for now until you buy new ones its not that dangerous unless the strut area/mount are rusted bad. i don't what part of jersey your from but i know down by the ocean the salt tears cars up and they can rust pretty bad. how many miles are on your car?
  12. #12 Re: How to tell if struts are bad?
    Oct 2011
    New Jersey
    It has 130k miles, and yes i'm not trying to spend a lot of money at all because i can't afford it right now lol
    Rear gp springs dont last for "life" lol. Ass sag is everywhere.
  14. #14 Re: How to tell if struts are bad?
    Jan 2012
    Philadelphia
  15. #15 Re: How to tell if struts are bad?
    Antioch, IL
    I got the ebay specials on my rears. Prime choice quick struts I believe. Love them, put them on last summer. Took a bit to get used to the rear end sitting higher after the install.
  16. #16 Re: How to tell if struts are bad?
    Oct 2011
    New Jersey
    Found some on rockauto between $38-70 dollars and its the same brand, i just need to find out if my fronts bad or its the back
  17. #17 Re: How to tell if struts are bad?
    Jan 2012
    Philadelphia
    if your rear feels all spongy and like a trampoline its probably your rear struts
  18. #18 Re: How to tell if struts are bad?
    Antioch, IL
    $38 ones wont be quick struts. I prefer no assembly required just bolt in.
  1. Struts
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-16-2012, 08:31 PM
  2. what other struts can i run on my 98 gp
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2011, 08:43 AM
  3. kyb struts
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 05-07-2010, 06:19 PM
  4. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  5. New Struts
    By Bigbm80 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:55 PM
