Thread: Struts
Results 1 to 17 of 17
  1. #1 Struts
    GT Level Member gunsn88's Avatar
    May 2011
    Vineland, New Jersey, United States
    hey anyone know of a link to the right strut tool i can use on my car. im replacing the struts and needs a speciol tool to do it. thanks.
    Imagination is more important then knowledge.
  2. #2 Re: Struts
    i bought mine at advance auto. you need the one with two clamps like this:
  3. #3 Re: Struts
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    Only special tool you will need is a coil spring compressor. :roll eyes: Two bolts at the bottom and three at the top remove the entire assembly just be careful the spring is strong. With the spring compressed you will need a allen wrench to hold the shaft so you can loosen the bolt. For the cost just replace the top mounting assembly don't use the old one and make sure you rotate the spring into the rubber mount before you retighten the bolt. It's not hard I'v done it so many times now it takes me about 10 min the get the assembly out. The back ones are a little harder because getting to the top bolts is a pain there is not a lot of room to get to the bolts in the trunk I use a ratchet wrench set for through bolts it's not a deep as a regular ratchet and socket so fits better. good luck the first time.
  4. #4 Re: Struts
    use an impact and you don't need to do anything special with the big top nut.
  5. #5 Re: Struts
    May 2011
    cool thanks guys. hopefully my advanced auto has one
  6. #6 Re: Struts
    May 2011
    and can u guys explain what kind of strut tool this is for? it looked interesting when i saw it. and i found the one at advanced you told me just waiting for next pay check.
    Buy OTC STRUT TOOL SET OTC4533 at Advance Auto Parts_____
  7. #7 Re: Struts
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Just Go to Oriellys and borrow the tool. Pay the deposit. Do the struts within 24-48 hours and take the tool back. Get deposit back... Done.
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  8. #8 Re: Struts
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    Its not a strut tool, Its a spring compressor!
  9. #9 Re: Struts
    michigan
    ^^thank you.....lol
  10. #10 Re: Struts
    Kansas
    What Brian said... go rent it and return it free o' charge.
  11. #11 Re: Struts
    the one they tried to rent me was the wrong one. i had to buy it.
  12. #12 Re: Struts
    Dec 2011
    Cadiz, Ky
    Never had a Problem. I work at a Body shop and we seldomly need to replace a strut. But when we do We go and rent it.
    The Boss Iceman6669's Avatar
    Jun 2011
    OR..... Just go out and buy loaded struts.... Saves tons of time... Just sayin
    2011 F-150 Yote powered
  14. #14 Re: Struts
    Quote Originally Posted by Iceman6669 View Post
    you're not saving any money that way, either.
    Jun 2011
    That's true and all but time is money... Lol... Plus doing loaded struts gives you all new stuff(springs, mounts)
  16. #16 Re: Struts
    all the loaded sets are not worth the money people pay for them.
  17. #17 Re: Struts
    Dec 2011
    indiana
  1. what other struts can i run on my 98 gp
    By nicks98gtp in forum Brakes/Suspension/Chassis
    Last Post: 08-04-2011, 08:43 AM
  2. Need new struts
    By Will5600 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2010, 11:01 AM
  3. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  4. New Struts
    By Bigbm80 in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:55 PM
  5. Struts!!!!
    By MizzBecca in forum Brakes/Suspension/Chassis
    Last Post: 06-09-2009, 11:52 AM
