Thread: 3100 SFI Hesitation Problem HELP
Results 1 to 9 of 9
  1. #1 3100 SFI Hesitation Problem HELP
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    1994 Grand Prix Coupe with the 3.1l SFI. When the engine is cold and i press the gas it bogs down. Ive looked this engine over top to bottom and cant find anything TB tps and iat check out ok. EGR is acting weird but seems to be doing the job. New airfilter on it, new plugs and wires. If I pump the gas pedal and press it down about half way the rpms go to about 1500 and 2 seconds later goes back up to normal rpms. This repeats until engine is warm. Please help
  2. #2 Re: 3100 SFI Hesitation Problem HELP
    new britain, ct
    it sounds like your MAF could be a culprit. my car just recently started doing this as well, gonna pick up some MAF cleaner and clean that and see what changes.
    also just curious if you replaced plugs and wires with stock?
    07 Black GXP.
  3. #3 Re: 3100 SFI Hesitation Problem HELP
    Nebraska
    yeah just ac delco wires and plugs. I dont have maf atleast as far as i know where is your located?
  4. #4 Re: 3100 SFI Hesitation Problem HELP
    new britain, ct
    im pretty sure you do as ii think 94 was the year they switched the OBD from 1 to 1.5. it is in the top of throttle body. ill try and snag a pic from my 95. you might want to clean your throttle body as well now that i think about it. buy some TB cleaner for it.
    07 Black GXP.
  5. #5 Re: 3100 SFI Hesitation Problem HELP
    Nebraska
    yeah im going to clean the tb tonight what cleaner do you recommend?
    This is my Throttle Body - http://parts.nalleygmc.com/images/pa...20GM03-317.JPG
  6. #6 Re: 3100 SFI Hesitation Problem HELP
    I swear to gawd guy if you make another thread..........
  7. #7 Re: 3100 SFI Hesitation Problem HELP
    Nebraska
    my bad this site takes some time to get used to
  8. #8 Re: 3100 SFI Hesitation Problem HELP
    We'll you don't need to click post a new thread everytime you post.
    Just click in the thread you started and reply in it.
  9. #9 Re: 3100 SFI Hesitation Problem HELP
    Nebraska
    oh ok. thanks
  1. Hesitation Problem
    By sbellmore2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2010, 01:11 PM
  2. Hesitation problem
    Last Post: 11-03-2010, 09:41 PM
  3. need help with hesitation problem
    By sbellmore2010 in forum General Tech Discussion
    Last Post: 11-01-2010, 02:59 PM
  4. 03 GP 3100 sfi fuel problem?
    By dirtfan50 in forum General Tech Discussion
    Last Post: 09-26-2010, 04:51 PM
  5. Hesitation problem
    By 4boostin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 11:41 PM
