i adjusted the grommet on the MAF sensor holder thingy..
it stopped whistling for a little bit! so think it's just a leak?
Points, In theory it should work. i'm not entirely sure of this. as i'm new to the grand prix scene, but i have found about 99% of the parts are interchangeable through Series 2 and 3
when the tb plate is partially open, the whistle is air going around it...
manually put it in 2nd around 30-35 and climb to 3k with the cutout open or closed and you hear that whistle.....makes me drool lol especially around this one curve on the highway next to the concrete divider where the sound bounces off of it...i love it
As far as i was aware, the plastic cover, the intake manifold were the only things that didnt fit. but that's all the previous owner told me. I believe the transmissions are the same from 97 to current
no...97 and 03 are different from 98-02 gt wise.
03 is different from 97-02 gtp wise
04-05 comp g is way different than 04+ gtp and gt(supercharged)
04+ could have different gear ratios than others..
best for you to stick to the gt reference up above.
or just go turbo
like i said, whistling wont go away
series 2 ands series 3 heads lim and uim are diff blocks are the same
