Thread: intercooler questions
Page 1 of 3 123 LastLast
Results 1 to 20 of 60
  1. #1 intercooler questions
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i am considering going intercooled but i have a few questions
    first i know the ZZP short stack IC isnt preferred but if i could get one for $250 should i?
    also how hard is this to install into a 99 GTP?
    (this is gonna sound dumb) what makes the pump work, is it electric?
    it seems really straight forward a lot like the engine coolent system ive replaced pretty much all of that on these cars before, id just like to hear from some people who've already done it thats all
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: intercooler questions
    If you can pull the supercharger off you can install an intercooler. The pump is electric.
  3. #3 Re: intercooler questions
    Oct 2011
    Michigan
    you pop the fuel rails off then theres like a few bolts that hold the S/C on its easy
  4. #4 Re: intercooler questions
    GTP Level Member
    Pittsburgh
    Just there are better options than the SSIC. You might as well pick up a IC from sseimnop seeing you will have much larger gains, and safety net
    2003 SSEi,
  5. #5 Re: intercooler questions
    Oct 2011
    Michigan
    ok i understand that bigger intercoolers will give you more power and what not but what are the problems with the ZZP SSIC besides the lack of gains?
  6. #6 Re: intercooler questions
    GTX Level Member blackflag's Avatar
    Virginia
    Warpage, its too thin. but for $250 not warped id buy it.
  7. #7 Re: intercooler questions
    Virginia
    btw your threads aggravate me. Ive read tons of threads on I/C's that have a plethora of info. Search.
  8. #8 Re: intercooler questions
    Oct 2011
    Michigan
    what part warps the heat exchanger or the core part that goes between the S/C and the engine?
  9. #9 Re: intercooler questions
    Virginia
  10. #10 Re: intercooler questions
    Pennsylvania
    Quote Originally Posted by asite57 View Post
    Bingo.
    "Skip the Short Stack. Save your money and buy at least a Stage 2. The Short Stack is half the price, but you get what you pay for. They heat soak very quickly and are just not really thick enough to do any good, plus they have had warping issues."
  11. #11 Re: intercooler questions
    Oct 2011
    Michigan
    i have searched there wasnt much that came up a lot of pages on here have dead links on them and that page doesnt really adress SSIC all it says is dont buy one but spending 1300 on a stage 2 IC isnt really doable at all
  12. #12 Re: intercooler questions
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Then dont go intercooled unless your going for big mods. if you dont have a grand to spend on a Stage 2, then dont buy one.
  13. #13 Re: intercooler questions
    if you buy a SSIC for 250 youre still gonna have to get the fittings, heat exchanger, ect.... and assuming you get it new itll be close to a grand...
    a stage 2 has more advantages than just "more power" (technically its better at dropping temps not increasing hp) and is a way better investment...
  14. #14 Re: intercooler questions
    Oct 2011
    Michigan
    well id get everything except for the hoses for 250, im not going for big mods the goal is 300hp at the crank
  15. #15 Re: intercooler questions
    Jan 2012
    Philadelphia
    the only think stopping me from going intercooled is the price of fuel rails, though my car is not modded to much at all yet
  16. #16 Re: intercooler questions
    Oct 2011
    Michigan
    the fuel rail spacers are only like 70 bucks
  17. #17 Re: intercooler questions
    Quote Originally Posted by gtpeddie View Post
    you can use stock fuel rails...
  18. #18 Re: intercooler questions
    Jan 2012
    Philadelphia
    from where?
    Quote Originally Posted by gtpsleeper View Post
    so you can do it with the fuel rail spacers?
    never knew that but haven't really done much research on it
  19. #19 Re: intercooler questions
    Oct 2011
    Michigan
    have you already bought the kit? its an option on the zzp website why your selecting your kit
  20. #20 Re: intercooler questions
    cut your stock fuel rails and use a fuel hose... 5 bux at napa and works like a charm....
  1. Intercooler questions
    By Freddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2012, 09:55 PM
  2. Intercooler install questions
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2011, 09:50 AM
  3. intercooler install questions
    By screamingreenmonster in forum General Tech Discussion
    Last Post: 05-17-2010, 05:17 PM
  4. intercooler questions
    By blowfishRus6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2009, 04:22 PM
  5. Handful of Questions for an Intercooler Install
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2008, 07:27 AM
