Thread: Is the ignition key the same as the door key in a 2004 grand prix?
Results 1 to 9 of 9
  1. #1 Is the ignition key the same as the door key in a 2004 grand prix?
    Jul 2010
    Canada
    I have a 2004 grand prix and the key has never been able to unlock the door. I bought this car in 2009 so I am not the original owner. The ignitian key works for the glove box, trunk and to start the car but not for the door. My remote for unlocking the doors is not working at times and I have to climb through the trunk to get in the car at times. It is a real pain. Is there a seperate key or is there something wrong with my lock. I read somewhere that it dries up over time from not using it and to spray wd-40 inside to lubricate is this right?
  2. #2 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    should be the same key, try putting some wd40 on the door lock
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #3 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    GTX Level Member blackflag's Avatar
    Virginia
    Same key for me and lol at crawling through trunk. It was a great visual in my mind.
  4. #4 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    Kansas
    I would also suggest getting new rubber buttons for the key fob. I've had good luck with replacing them due to intermittent fob issues. Plus it's only a few bucks.
    And yes, same key works for ignition, trunk, and doors.
    If you have remote start:
    NEW GM KEYLESS ENTRY REMOTE 5 BUTTON RUBBER KEY PAD | eBay
    Otherwise check the guys store for others.
  5. #5 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    GT Level Member GMCustomerService's Avatar
    Michigan
    bjornbjorn,
    The key can be used for the ignition, as well as the driver’s door lock and storage compartments.
    You may want to try WD-40. If that doesn't work, consider have a certified tech take a look at it.
    Keep us posted.
    Louis
    GM Customer Service
  6. #6 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    New Brunswick
    Possible that the door might haved been changed all together but likely just seized up. Check the sticker inside the door by the latch and see if the vin numbers match up and let us know.
  7. #7 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    you could if all else fails, just go buy 2 new door locks and put them in your doors, you now have a new door key, but you are also not crawling through the trunk.
    remove door skin, and they are held in with a clip. thats it.
    and your key fob, have you changed the battery? or made sure the contacts under the buttons are clean? i just cleaned mine and im back to a 100 foot range.
  8. #8 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    Portland Oregon
    I'm guessing your door lock seized up like my trunk lock was. I had an 04 and the trunk lock never turned. It turned out to be a little corrosion. I removed the lock cylinder and tapped it with a small hammer to break the corrosion free and shot some white lithium grease in there to keep it from happening again. Haven't had a problem since. I check them from time to time not using the key fob as well so as to make sure they aren't freezing up.
  9. #9 Re: Is the ignition key the same as the door key in a 2004 grand prix?
    GT Level Member tylerbinski's Avatar
    Canada
    Same story for me, except that I cannot climb through the trunk... That too is seized.
    I am going to take a look and see if i can get some penetrating spray in there and also take the lock cyclinder out and bang it around to remove corrosion etc.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  1. HELP HELP! 99 grand prix 2 door DOOR HINGE REPLACEMNT
    By blortz in forum General Tech Discussion
    Last Post: 05-31-2011, 08:52 PM
