Thread: manual fan switch: good idea bad idea?
Results 1 to 8 of 8
  1. #1 manual fan switch: good idea bad idea?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    is it a good idea to install a manual fan turn on switch then use it to keep the car cool i would turn it on at like 175* is this a good idea or just s really stupid one?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: manual fan switch: good idea bad idea?
    Mar 2012
    NC
    That can be done with tuning software. I wouldn't recommend it though as the engine would never fully come up to temperature.
  3. #3 Re: manual fan switch: good idea bad idea?
    Oct 2011
    Michigan
    i was just tossing this idea around i think id be neat and i could leave them on for a minute or so after i turned the car off to cool it a bit
  4. #4 Re: manual fan switch: good idea bad idea?
    Mar 2012
    NC
    Can also be done with tuning software.
  5. #5 Re: manual fan switch: good idea bad idea?
    if you cant find a tuner, you can get a new thermostat for the fans that you can tune to turn on at what ever temp you want to, you will need to wire up a relay switch and the new t stat.
    google up automotive electric fan thermostat they are sold all over the net.
  6. #6 Re: manual fan switch: good idea bad idea?
    Mar 2012
    NC
    I figured being in the GP mecca of the US, he should be able to find someone there to hook him up. LOL
  7. #7 Re: manual fan switch: good idea bad idea?
    thats just what i did to wire up electric fan in my puck up truck, when the clutch fan went bad for the 3 rd time. it was cheaper to take off the fan and swap in 2 16 inch fans 2 relays and a switch and the new t stat.
  8. #8 Re: manual fan switch: good idea bad idea?
    Oct 2011
    Michigan
    alright thanks guy
  1. Another manual idea
    By crzystve42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 08:54 AM
  2. Good Idea or Bad Idea?
    By Robby Avery in forum Turbo
    Last Post: 01-25-2011, 04:55 PM
  3. Good idea - Bad idea?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 04:51 PM
  4. good idea or bad?
    By GTPJOE90 in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2008, 09:58 PM
