Thread: cooling fans on 90 G.P.
Results 1 to 19 of 19
  1. #1 cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    GOOD MORNING, I'M NEW HERE AND WOULD LIKE TO THANK EVERYONE FOR HELP.I have a 90 Grand Prix my driverside fan seem's to be working [turns on around 225deg.]but the passenger side runs ALL the time!Even cold with car off! I've changed relay's, i've changed eng. coolant sensor! I've read both fans should kick on when a/c is turned on but they dont, the driver side WILL come on like i said around 225deg. Passenger side runs all the time. I thought about just running a togel switch to control passenger fan, but would rather fix the prob. right.THANKS FOR YOUR HELP! [I'm mechinaly inclined NOT electricly!]
  2. #2 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    Make sure someone hasn't hard-wired the fan. Make sure there isn't a short behind the fuse panel. Get a wiring schematic for the car. ALLDATA is a great place to start.
    1) Does the fan shut off when you remove the relay?
    The relay receives a low current signal from some control circuit, either a sensor or the ECM, and this activates the relay coil. It's just a switch which in turn completes a high current circuit within the relay. This is the way our cars keep high current circuits in check. Low voltage signals from anywhere in the system to a centralized high current location (fuse/relay box).
    2) If the fan stays running with the relay pulled then the fan is either hard-wired or there is a major short somewhere on the motor + wire.
    3) If the fan does in fact shut off with the relay removed then check that the relay control signal isn't shorted to a supply somewhere in the system. To test the control wire, disconnect the battery and pull the relay. Check continuity from the relay control pin to the + battery cable. It should be open or very high resistance. If there is 0.5 ohm or less then the wire is shorted to 12V somehwere in the system; possibly behind the fuse/relay panel.
    4) If it's getting the signal from the ECM then you have a real problem. That's, of course, if the OBDI is actually designed to control it. Someone may have flashed the EPROM incorrectly. You'll have to have someone reflash it or get a OBDI tuner kit. The ECM could be defective also.
    How long have you had the car? A little history is always helpful.
  3. #3 Re: cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    thank's Rico,it does stay running when the relay is pulled! So it's a short on the + side uh,I'll try to trace it down.the car is my daughter's car,it only has 64000mi but it's been sitting 3yr's. I know that NOT good on a car. She drives a 07 grand cherakee limited and her husban has a little ford ranger and dont have a mechanacly inclined bone in his body.So they just let it sit.The car is in pretty good shape[other than paint badly peeling].But anyway i replaced dryrotten tires,changed guage cluster because the tach was pegging out and speedometer didnt work [fan prob was before i switched guages]now all guages work.The relays been replaced,the temp. switch replaced, the fan on the driver side didnt work[checked by wireing straight to battery]replaced it.It's strange though,the fan on the driver side turns on at 225deg. and off at around 180deg.shouldnt that be what the passenger side do?I thought the A/C fan[passenger side]worked like that and the one on driver side is supposed to come on when temp. got around 180deg.Any help is GREATLY APPRECIATED.
  4. #4 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    It looks like the ECM does in fact control the fans. The ECM is also interfaced with an AC control module somewhere in the car. The AC control module may be your problem with the driver's side fan. It's a dealer part and it's very expensive. Junk yard may be an option.
    There is an auxillary fan controller available. It requires splicing into the AC compressor control wire to turn on the fans. It comes with the neccesary wiring and a thermostat that mounts on the radiator or on the engine block.
    NOTE: This wouldn't explain why the passenger fan stays on; unless there are separate relays for the fans that you are unaware of. Keep looking for a short in the motor + wire if you're sure the fan stays running without the relay.
    Question: Are there two relays; one for each fan?
  5. #5 Re: cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    first of all,thank you for the ECM pinout! the 90 grand prix LE 3.1 has 3 relays in eng. compartment passenger side inner fender,one relay for each fan and a relay for the A/C cluch, i've changed all 3 relays.I'm trying to find out now if there ain't another switch that controll's the fan's.I've read on one post that there was one on the back head on driver side with one green wire comming from it BUT it was on a newer GP with the 3.1,I believe 93 or 95 somthing like that.I also read the ECM sends the signal to the relays witch in turn controlls the operation of the fans.I was thinking of replacing the EMC with one from the bone yard!! If i do replade the ECM would i need to have it reprogramed? What if i can get one from the same yr.and eng.size, would IT need reprogramed?
  6. #6 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    OK here is the exact ECM pinout for the 3.1L V6 (though it was a I4)
  7. #7 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    Here is the body wiring diagram for a 1991 Grand Prix...should be the same for 1990.
  8. #8 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    I know that the body diagram is difficult to understand but you have find out which VIN your car is and follow the schematic.
    There are four possible VIN's:
    1) VIN L
    2) VIN T
    3) VIN 4
    4) VIN X
  9. #9 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
  10. #10 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    If you have definately pulled the relay that controls that particular fan then I believe the fan should turn off. I doubt that there is another high current circuit for the fan. The fans may be turned on at different times for different reasons, all of which are via the relay. You say that the ECM controls the fans via the relay. Why is it still running without the relay? There is probably a short somewhere on the + motor wire as mentioned previously. We cannot determine wether or not the ECM is faulty at this time. So do not possibly waste your money on another ECM.
    Don't worry about the temperature sensor that is somewhere on the motor. It's just a generic switch that tells the ECM if the engine temperature is above a certain value like 225 degrees. This leads us back to the same problem; even if the temperature is above the pre-determined value we can't tell if the ECM is actually sending a signal to the relay because the fan is hard-wired or shorted.
    I'll get some more schematics that might shed some light on the fan circuits and how they interact with the rest of the system. The fan relays may actually be grounding switches. This means that there may always be power to the + motor wires and the relay completes the ground circuit. A good test would be to remove the connector from the fan that is working and see if there's 12 volts on the + motor wire when the car is off and key in the "on" position. This will tell us if the fans are controlled by the relay as a ground return.
    In the mean time trace the wires for the fan and make sure there's nothing shorted.
  11. #11 Re: cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    Just wondering...since the fan on the driverside fan seems to be acting like IT ought to be the one on the passengerside [A/C fan] ,could it be possable the plugs on the ECM for the fans be pluged in backwards?Or can they only plug in one way? Autozone says there is a cooling fan controll switch on the bottom passenger side of radiator.I haven't notice it,i know there is a coolant level switch on top passenger side! i haven't had time to work on it the last couple of day's, but have been trying to find somthing on the internet about this when i get a little time.Will try to get over there today to check to see if there is a switch on the bottom of radiator or not and trace wires. the vin code is T.THANK'S AGAIN FOR ALL YOUR HELP!!! Elec. problems uuuugh.
  12. #12 Re: cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    Well i did find someone had the fan wired direct to a hot wire.I rewired the passenger fan back the way it's supposed to be [black wire to black wire and orange with black stripe to orange with black stripe]on both driverside and passengerside. Now the passenger fan no longer stay's on, but it don't come on at all and the one on the driver side is acting like the auxilliary fan[passenger side]fan. It comes on at 225deg. and goes off around 180deg.shouldn't that be the A/C fan[auxilliary]passenger side? They seem to be in the reverse order!!! Oh they can't be pluged in backward on the ECM, they can only plug in to matching outlet.This realy is a puzzle.The A/C cluch don't kick on either [probably no freon] but i wouldn't think that would cause the reverse fan order.Any idea's? CORRECTION the wire's going to the fan might be red with black stripe, and not orange with black stripe.
  13. #13 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    I kind of thought the fan was hard-wired.
    Your PCM senses that the AC is not working (AC pressure sensor). Fix the AC and the fan will turn on. Who cares which fan is coming on, as long as the fans come on. Without the AC on, one should come on at 225 and the other should come on at 235 or something. The engine may not be hot enough to turn both fans on yet.
    Look on the back of the fuse/relay panel and see what ECM AC control wires are going to which fan relay.
    Dark Green/White = Fan 1 relay
    Dark Blue/White = Fan 2 relay
    I don't know which fan is 1 or 2, driver's side or passenger side.
  14. #14 Re: cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    Thank's a million for all your help with this, i unpluged the A/C pressure sensor and ran a jumper wire and sure enough the fan came on! So i'm gonna get either a conversion kit for 134a OR try to find the hose for the r12 [i have 6 can's of r12].They were given to me when i bought my 89 trans am [28,000mi. 3yr's ago] 5.0 tpi now it has 36,000! I've switched it to 134a. I herd the r12 is fetching a pretty penny so i'll probably save the r12 to sell and switch the grand prix to 134a.YOU'VE BEEN A BIG HELP, THANK'S AGAIN!
  15. #15 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    Come back and see us again.
  16. #16 Re: cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    WELL...now that the grand prix is figured out, oh by the way the a/c pressure switch is bad [good pressure but not turning on cluch on compressor] i unpluged it, and now by turning a/c on high or defrost on, the fans come on! No air of course because the cluch isn't kicking on,but fan's work!Thought our reader's would like to know] i'm gonna take it and have it flushed out and then i'll change the pressure sensor and chang the fitting's to accept the 134a! like i said, now that that's figured out [with many thank's to you] i was wondering if you could help me with my 89 t/a? If i drive alot in hot weather or stop and go traffic the gas tank and fuil system build's up pressure and the car will just die,it always start's back up but once hot it will keep doing it.I changed the cap to a vented one but it still does it.Any idea's? I was thinking maybe the evap.canister?
  17. #17 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    Do you have DTC codes P045X or P044X?
    What to do:
    Get rid of vented cap
    Make sure solenoids are working (purge and vent)
    Temporarily bypass the canister
    Make sure vacuum lines aren't clogged and purge lines are good
    Run it and see what happens.
  18. #18 Re: cooling fans on 90 G.P.
    Apr 2012
    Cleaveland
    thank you,i'll have to check for codes.My check eng. light comes on once in awhile but goes back off! where would the solenoids be for the purge and vent? On my daughter's 90 grand prix, everything seems to be working now [fan's come on with A/C or defroster on,shut's off when turned off]. With a/c and defrost off,driver side fan will enguage around 225deg.and off around 180deg. Passenger side has not kicked on[probably because not hot enough]. Compressor cluch enguages with a/c or defrost on and shut's off when turned off! Just wondering...with a/c or defrost on and cluch enguaged,should cluch STAY enguaged or should it cycle on and off? Or stay on with a/c and cycle with defrost? I thought they should cycle[to keep from burning compressor up]but on some post they say it stay's on[post was on newer car's though]. If it IS supposed to cycle,then i'll need to chang the pressure sensor.I didn't want to change it unless i was sure it needed to be because of the location makes it kinda hard to get to.
  19. #19 Re: cooling fans on 90 G.P.
    Apr 2009
    Fort Worth TX
    There should be no difference in AC control between defrost and cabin cooling. The AC system is designed reach a certain system pressure and/or head pressure and that's it. Cooling is controlled by redirecting air, hot and cold, within the cabin.
    Some of the newer compressors have a built in bypass that prevents excess head pressure. They did this to prevent premature clutch wear. I don't know about the dinosaur that you are working with.
    I would bite the bullet and just change the pressure sensor. You're almost there. Don't muck it up over a sensor. If the system is cycled on/off via pressure sensor input then not changing it may damage the compressor or cause leaks. Peace of mind is worth it's weight in gold, no?
    1989 T/A 3.8L Turbo - Component location
  1. cooling fans always run
    By jaxso6 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-25-2011, 08:33 PM
  2. HELP! cooling fans not running
    By nauss in forum General Tech Discussion
    Last Post: 09-15-2011, 02:20 PM
  3. Cooling Fans Not Working
    By thewaitinggame in forum General Tech Discussion
    Last Post: 09-02-2011, 10:24 AM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
