Thread: 1st Design or 2nd Design Water Pump?
Results 1 to 5 of 5
  1. #1 1st Design or 2nd Design Water Pump?
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    Okay, so can't decide if my water pump seal or the pump is leaking... so im replacing both. Im getting an ACDelco one, but the 1st design is $88 on RockAuto with gasket, and the 2nd design is $44, and a gasket for $5... so why such a big difference?
    2001 GT - Mods, Magnaflow Mufflers, K&N CAI
  2. #2 Re: 1st Design or 2nd Design Water Pump?
    im not sure what you mean by the pump or a seal? just go to the parts store and buy one, they are around 50 i think. just did mine last year.
  3. #3 Re: 1st Design or 2nd Design Water Pump?
    Sep 2011
    Fort Worth, Texas
    Gasket. Oops haha
  4. #4 Re: 1st Design or 2nd Design Water Pump?
    take the belt off and see if the pulley has any play in it, if so its the pump, failed gasket is not likely.
    also check the plastic elbow just above the pump, it goes into the manifold, they like to crack or just leak sometimes, but not till the car is hot sometimes. water pumps like to leak after you turn the car off most of the time and will have wetness on the snout of the pump by the weep hole.
  5. #5 Re: 1st Design or 2nd Design Water Pump?
    Sep 2011
    Fort Worth, Texas
    Not sure where the weep hole is on this car specifically. But if looking directly at the pump, it has coolant on the top of it in the little groove and spray all towards the right where the inlet house is. Or at least the house on the right side.
  1. New Garage Design
    By Zef_66 in forum Off Topic Discussion
    Last Post: 03-23-2012, 01:48 PM
  2. Cam design
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 05:26 PM
  3. LIM Gaskets: First and Second Design
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 12-15-2010, 01:26 PM
  4. Sub box design
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2009, 02:10 PM
  5. SRT Design
    By flash527 in forum Track Sessions and Kills
    Last Post: 07-22-2009, 06:27 AM
