Thread: how do you all do an alignment on thses cars?
Results 1 to 20 of 20
  1. #1 how do you all do an alignment on thses cars?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i know how to do an alignment (im talking about front toe adjustment) and ive done it on my 99 GTP several times but i was using an alignment rack how do you all do it in your own garage on the ground? theres no clearance in theses cars or do you just kinda make it work?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: how do you all do an alignment on thses cars?
    Kansas
    Y U POST SO MANY THREADS??!?!??!!
    Hmmm.....
  3. #3 Re: how do you all do an alignment on thses cars?
    Oct 2011
    Michigan
    because i want to learn!!! google can not answer this question either
  4. #4 Re: how do you all do an alignment on thses cars?
  5. #5 Re: how do you all do an alignment on thses cars?
    Oct 2011
    Michigan
    im not trolling the fourm thanks for answering the question...
  6. #6 Re: how do you all do an alignment on thses cars?
    HUDSON
    Jack up car and get under to break the adjust lock nut loose, lower car to ground, Reach the tie rod to adjust by reaching your arm over the top of the tire, then retighten lock nuts.
  7. #7 Re: how do you all do an alignment on thses cars?
    Quote Originally Posted by QUICKSILVER462 View Post
    its a hell of a lot easier to turn the inner tie rod from under the rear of the front tire, just did this 2 days ago. with the wheels straight anyways.
    my inner tie rod went bad, i changed it, marked the old rod where the lock nut was, matched it all up and my steering wheel was off by 4 inches.
    i left the car running and turned the inner tie rod till the wheel went straight, test drive, readjust, a few times, its close, but not anywhere nears perfect. the only way to get it perfect is on a alignment rack. i need to go soon myself, this was just to keep me in the ball park till i get top the shop.
    i have seen on tv where they did a at home alignment, they just measured from matching tread on the tires, 1/8 smaller on the front side of the tire vs the rear of the tire.
  8. #8 Re: how do you all do an alignment on thses cars?
    Apr 2009
    Fort Worth TX
    Holy crap, I didn't know you could do this. Firestone has been ripping me off.
  9. #9 Re: how do you all do an alignment on thses cars?
    a laser alignment rack is always going to be a much better solution than doing it at home.
  10. #10 Re: how do you all do an alignment on thses cars?
    Apr 2009
    Fort Worth TX
    I'm gonna buy a laser. JK ^^^Agree
  11. #11 Re: how do you all do an alignment on thses cars?
    Two laser pointers duct taped to the front wheels, a couple 2x4's and you can do the rears too.
  12. #12 Re: how do you all do an alignment on thses cars?
    Apr 2009
    Fort Worth TX
    Bill, I'm trying to be troll today but you keep substantiating my comments. LOL
  13. #13 Re: how do you all do an alignment on thses cars?
    I'm a mod...it's either substantiate or infract.
  14. #14 Re: how do you all do an alignment on thses cars?
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    You can do it with string too, it gets it close enough to not make any wear difference. That said having an alignment done on a rack using a machine is always the best option.
    4 out of 3 people have trouble with fractions
  15. #15 Re: how do you all do an alignment on thses cars?
    Saratoga NY
    Just go somewhere that offers a lifetime grantee/alignment. If your doing it right they will see you every few months.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  16. #16 Re: how do you all do an alignment on thses cars?
    Quote Originally Posted by gmpowered View Post
    hah, i sure hope not.
  17. #17 Re: how do you all do an alignment on thses cars?
    Oct 2011
    Michigan
    agree this is the 4th alignment ive had to do on this car in the past 8 months
  18. #18 Re: how do you all do an alignment on thses cars?
    the alignment should be 100% for at least a set of tires. the only reason ive been to the alignment rack more than twice in the past year is because i swapped my suspension twice.
    and those lifetime alignment places dont align your car how you want it, they do it per the stock specs and that's it. so it's useless to anything looking to go aggressive with it.
  19. #19 Re: how do you all do an alignment on thses cars?
    Oct 2011
    Michigan
    Michigan roads+new tie rods+letting people drive your car= needing more alignments
  20. #20 Re: how do you all do an alignment on thses cars?
    Saratoga NY
    HA ha yeah those pesky alignment places, stock and thats it mang! lol
  1. Understanding Alignment - NOW WITH STOCK ALIGNMENT SPECS!
    By MrPoopyButthole in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2012, 10:05 PM
  2. what kind of abuse can thses cars handle?
    By asite57 in forum General Grand Prix Discussion
    Last Post: 04-11-2012, 06:38 PM
  3. Do I need an alignment?
    By skeelo58 in forum Tires & Wheels
    Last Post: 11-25-2011, 07:04 PM
  4. Alignment
    By dsh1106 in forum Brakes/Suspension/Chassis
    Last Post: 01-29-2011, 10:39 AM
  5. '01 alignment ?'s
    By riceburner in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 04:14 PM
