Thread: Leaking noise
Results 1 to 10 of 10
  1. #1 Leaking noise
    Apr 2012
    Wyoming, MI
    After I shut off my engine in my 2000 Grand Prix GTP, I hear some sort of gas leaking. At first it sounded like air still being sucked into my CAI, but now I believe it's a leak in the A/C. I cannot tell where it is coming from.
  2. #2 Re: Leaking noise
    Video would help if possible. And you mean it sounds like someone letting air out of a tire?
  3. #3 Re: Leaking noise
    Minnesota
    Mine does that too. I only notice when my hood is open tho. I believe it's coming from the brake booster?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  4. #4 Re: Leaking noise
    If you don't use the AC, you probably don't hear the noise..
    That's normal, it's the pressure etc n the AC system doing it's normal thing.
  5. #5 Re: Leaking noise
    Apr 2012
    Wyoming, MI
    Okay, because it only happens if I have the A/C on, and I'm scared that it is letting out freon. I had to recharge it this spring, so hopefully nothing is leaking.
  6. #6 Re: Leaking noise
    Pennsylvania
    The ac is a closed system, so if you had to recharge, you had a leak. Most r134a's out there have a leak sealer in them though, so it's possibly fixed for now. I doubt that's your noise though, if it was leaking fast enough to be heard it would be empty over night
    Sport Edition Kv5 18x8
  7. #7 Re: Leaking noise
    Minnesota
    I never use my ac. Honestly cant remember that last time I did haha So is that still what it is?
  8. #8 Re: Leaking noise
    Apr 2012
    Wyoming, MI
    My A/C still blows ice cold and the noise still happens when I turn the vehicle off, so it should be good
  9. #9 Re: Leaking noise
    Mercer, Pa
    its your ac refrigerant leaking through your orifice tube from the high pressure side to the low pressure side. Its normal.
  10. #10 Re: Leaking noise
    Ricky..that elbow from the hose into the booster is a check valve...you may want to check it.
  1. Leaking
    By gtpzmdc in forum General Tech Discussion
    Last Post: 08-17-2012, 01:59 PM
  2. Replies: 21
    Last Post: 03-07-2012, 02:10 PM
  3. Leaking oil all under car
    By GTLGDP in forum General Tech Discussion
    Last Post: 01-17-2012, 08:15 AM
  4. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  5. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
