Thread: Histitations and clicking tapping noise from engine at highway speeds ???
Results 1 to 10 of 10
  1. #1 Histitations and clicking tapping noise from engine at highway speeds ???
    Apr 2012
    weymouth, Ma.
    I have a 99 grand prix gtp and when im on the highway at about 60 and i go to give it gas the engine starts bucking and i hear like a clicking/tapping noise from the engine area. I was reading some post and maybe it could be a clogged cat? I thought it would be a transmission problem but im not sure. Has anyone else had this problem? thanks
  2. #2 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    gotta be a little more specific. do the symptoms happen when you're giving a lot of gas to get to 60 or a little gas?
  3. #3 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    Apr 2012
    weymouth, Ma.
    Quote Originally Posted by bps02gtp View Post
    It does it at full throttle so alot of gas.
  4. #4 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    Nov 2010
    Illinois
    Yeah at full throttle it very well could be a clogged cat. How many miles first of all?
  5. #5 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    Apr 2012
    weymouth, Ma.
    I actually have a code in there for p0303. The car runs fine no misfire at regular driving though. I have 148,000 on it.
  6. #6 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    Apr 2009
    Fort Worth TX
    Change the plugs and wires yet?
  7. #7 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    Apr 2012
    weymouth, Ma.
    Quote Originally Posted by Rico View Post
    I just bought the car but the guy i bought it from said he put new plugs and wire in it. The wires do look new. I looked a the freeze frame data and the misfire happens at 44 mph and at 4800 rpm. And the car runs fine just normal driving around the city no mifires.
  8. #8 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    Apr 2009
    Fort Worth TX
    What kind of plug wires are they? Are the coils stock?
  9. #9 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    Nov 2010
    Illinois
    those coils might still be ok but you might want to pop them off and take a look to see how they are. probably wouldnt hurt to replace the plugs on your own to make sure they're good. if the misfire only comes at WOT then it could be a lack in fuel pressure or a clogged cat. that would be my guess.
  10. #10 Re: Histitations and clicking tapping noise from engine at highway speeds ???
    St. Louis
    Make sure you use either stock Delco Irridiums, or a good copper plug. Do NOT use any Bosch or Platinum plug as the ignition system in these cars tears them up.
  1. Engine tapping noise under load and cold only
    By mojonba in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 09:07 PM
  2. Vibration at highway speeds
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 09-27-2010, 08:10 PM
  3. Shutter while downshifting at highway speeds (50 to 65 MPH)
    By GPdude97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-23-2009, 02:52 PM
  4. vibration at highway speeds
    By dagger in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 07:42 PM
  5. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
