Thread: No radio lights.
Results 1 to 2 of 2
  1. #1 No radio lights.
    GTP Level Member 99gpse's Avatar
    Dec 2008
    Freeman, SD.
    No this isn't the typical my display doesn't work, it does, but when the lights are turned on, it goes off, and none of the lights come on the radio. I've tested it in another car, and tested another known good radio in this car, with the same results, both radios go dark when the lights are turned on in the GP. I looked at the adapter harness from the aftermarket radio that was installed and found the "Dimmer" and "Illumination/ Dash Light" wires and disconnected both, it looks like the Illum wire does nothing, and the Dimmer wire causes the display to go out. I'm not exactly sure how this works, most cars I've worked on had one wire that did both, my best guess is that the Dimmer causes the display to go out, and the Illum is the one that controls the brightness of the lights. The rest of the lights in the car work fine, is there a problem with this wire? Should I run a jumper wire from it to the climate control lights? Help please, it's annoying not having lights on the radio at night!
    I forgot to mention, the car has a factory CD player. I took out the aftermarket one and put a factory one in.
    '90 Acura Legend LS V6 2.7 5MT ^
    '87 Acura Legend V6 2.5 5MT
    '94 Saab 900 SE V6 2.5 4AT
  2. #2 Re: No radio lights.
    Dec 2008
    Freeman, SD.
    Quote Originally Posted by 99gpse View Post
    This is exactly what I just did and it worked. The dimmer switch doesn't work, but that didn't before. The lights don't dim when you turn the switch down, but the lights are working on the radio like normal now.
  1. dic and radio lights are out
    By Noxas in forum Audio, Security & Visual Electronics
    Last Post: 11-21-2011, 10:02 AM
  2. Radio lights?
    By grand prix newb in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2011, 09:21 PM
  3. Installed aftermarket radio, now no interior lights
    By Tommyp2010 in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2010, 05:32 PM
  4. interior lights very dim,shutting radio off.please help
    By dvandemark in forum General Tech Discussion
    Last Post: 12-06-2009, 05:06 PM
  5. HVAC Cluster Back Lights / CB Radio Install
    By POLECAT2007 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2009, 09:47 AM
