Thread: a/c not working and heat not switching to floor help!!!!!!!!!!!!!!!!!!!!!!!!!!
Results 1 to 2 of 2
  1. #1 a/c not working and heat not switching to floor help!!!!!!!!!!!!!!!!!!!!!!!!!!
    usa
    need help. my heat doesnt switch to the floor and the a/c dont work. everything under the hood works it just wont go through the firewall. is it the blend door actuator that is preventing this?
  2. #2 Re: a/c not working and heat not switching to floor help!!!!!!!!!!!!!!!!!!!!!!!!!!
    St. Louis
    Either that or you have a bad HVAC head (vacuum leak). What do you mean by the "AC doesn't work"?? Does it blow cold just not through the vents, or do you not get cold air at all. Also, post what type of climate control you have (manual 3 knob, dual zone). If the A/C isn't cold then I would start by checking to see if the system is full of freon. If not, then charge it and see what you get. May have a leak somewhere.
  1. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  2. Switching DIC
    By ndgprix in forum General Tech Discussion
    Last Post: 12-08-2010, 02:30 PM
  3. Thinking about switching oil
    By Pontiacman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2010, 11:51 AM
  4. problem #2.. #5 on heat control not working
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 12:13 PM
  5. switching to dexron VI in an 02
    By adamlesandrini in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2009, 03:07 PM
