Thread: Blower motor nightmare
Results 1 to 7 of 7
  1. #1 Blower motor nightmare
    Apr 2012
    Windsor
    2005 grand prix gtp comp-g
    Hey, So the other day i took my car for a car wash, it was pretty cold about -32F, did not think much about it, after the car wash i had the heat blowing high on the windshield so i did not fog up and drove for about 15 min back to my place. Later that day i went to go out and noticed that my interior fan was not blowing... i figured some water got in the fan and its frozen, so next day i took it to a shop i go to sometimes and asked the guy to pull it in overnight and try it in the morning.
    So next morning i get a call from the mechanic and he says that the blower motor is filled with water and will have to be replaced, he quotes $325 for parts and labor, (Right away i know that's pretty high, But this shop does good work and is one of those napa autopro shops so the parts are usually of a good quality. And i have no heated place to work or i would of just done my the job myself). He also mentions that he can seal the leak where the water came in for another $300, I declined that since that's just crazy.
    So now my blower motor works but i have noticed that if i turn the fan setting to max it does not blow nearly as hard as the old one use to, I would say max on this fan is about 60% on the other, So any reason for this? Is there a way he used a lower RPM fan or something and i way i could prove it so i could go back there?
    And also the mechanic said the water came in from the wiper cowl, It lifts up near where the cabin filter sits, I was thinking some double sided tape but i am not sure that will be strong enough. Any other ways of making it seal to the windshield but still be easily removable if i have to go in there, (cabin filter, Wiper motor)
  2. #2 Re: Blower motor nightmare
    May 2012
    Cedar Rapids, Iowa
    I bought an after market blower motor for my 05 as well. Its not nearly as good and definitely louder. There's only 3 bolts holding it in under the passenger side dash and super easy to replace. I think the aftermarket ones just suck.
    There's a part to buy that deflects the water. For some reason I can't link things, but go to the how to section. Its called water in the floor board take 2. It gives the p/n to fix the part
  3. #3 Re: Blower motor nightmare
    May 2012
    Cedar Rapids, Iowa
  4. #4 Re: Blower motor nightmare
    heres your cowl fix, its less then 10 bucks and can be changed in 15 minutes. http://www.grandprixforums.net/showt...ass+side+floor
    cant help with the fan. other then my sympathy's for the shop bill.
  5. #5 Re: Blower motor nightmare
    Apr 2012
    Windsor
    thanks for the link, looks like a good fix, that piece will fit an 05 grand prix right? looks like the car hes putting it on is the earlier body model.
    Also i have read that if the blower motor is wired in reverse it does not blow properly, think maybe thats the issue or does it use a connector harness?
  6. #6 Re: Blower motor nightmare
    pretty sure that part # works for all W bodys.
    the fan wires, im sure if you wired it backwards it would run backwards.
  7. #7 Re: Blower motor nightmare
    The blower motor can only hook up one way. That piece fits the 04+ as well I did it on mine. I also swapped my blower motor a few months ago in about 10 min.
  1. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  2. Blower Motor or Blower Motor Resistor???
    By soverstreet4472 in forum General Tech Discussion
    Last Post: 10-08-2012, 06:50 PM
  3. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  4. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
