Thread: Unable to remove key from the ignition.... intermittently.
Results 1 to 7 of 7
  1. #1 Unable to remove key from the ignition.... intermittently.
    Apr 2012
    Sinsinnati,OH
    I am have a problem with my 03 GTP, that it seems quite a few others have had. When I shift into park, sometimes I cannot get the key out the ignition. I have to jiggle/move the shifter around and eventually it will let go of the key (let me turn it so I can remove it). Most of the time the key comes out fine, but increasingly I have fight with the shifter to get it to release.
    Note that I am not having trouble shifting it out of park.
    I've searched the forums and noted alot of people just remove the solenoid. Before I go that route, can someone tell me if/where the switch is that tells the solenoid that it is in park (the park lock switch?)? As I suspect this is problem...e.g switch is going bad or dirty.
    Thanks for advice....
  2. #2 Re: Unable to remove key from the ignition.... intermittently.
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I have the same exact problem, i actually just got in and had trouble trying to get my key out for about 5 minutes
  3. #3 Re: Unable to remove key from the ignition.... intermittently.
    Apr 2012
    Sinsinnati,OH
    FWIW there is a little access port under the steering column that can be used to manually release it.
  4. #4 Re: Unable to remove key from the ignition.... intermittently.
    SE Level Member thenose's Avatar
    Apr 2012
    Athol, Massachusetts
    Quote Originally Posted by ronmexico View Post
    I have to do this with my car. You can just stick a little object up and release it (I use an allen wrench). Look under the column for a small hole, looks like a screw access hole.
  5. #5 Re: Unable to remove key from the ignition.... intermittently.
    Somewhere on here is a guide for a temp fix for that, basically you remove the lower part of the steering column and ziptie the little button down.
  6. #6 Re: Unable to remove key from the ignition.... intermittently.
    Apr 2012
    Quote Originally Posted by slick2500 View Post
    Boy, THAT would make the wife happy (it's actually her car)
  7. #7 Re: Unable to remove key from the ignition.... intermittently.
    Mar 2012
    michigan
    yup i just carry a lil screw driver in my center consel
  1. unable to post pictures
    By 99GPGTP in forum Off Topic Discussion
    Last Post: 07-14-2011, 09:10 PM
  2. Unable to peelout
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 07-06-2010, 10:34 PM
  3. HUD and GPS going out intermittently?
    By Jas0n in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2010, 08:22 PM
  4. Key intermittently won't come out of ignition
    By atclarkson in forum General Tech Discussion
    Last Post: 06-09-2010, 09:47 AM
  5. Help!! Unable to CASE Learn
    By jamster00 in forum General Tech Discussion
    Last Post: 06-18-2009, 09:06 PM
