Check fuses. You may have melted the one for the MAF. It's in the power distribution box under the hood.
EDIT: It said low activity, not no activity. My bad. I'd check for vacuum leaks. It's quite possible you shifted a gasket during the build.
hey guys! thanks for the input!!
however i heard a knock from the top end so i checked out with a stethoscope and it sounded like the SC was knocking.. so i took the SC belt off to see if the noise stuck around and it did.. so now im going to check my compression in all six. ill keep you posted! thanks again!!
