Thread: squirel ate my wiring harness, need help
Results 1 to 4 of 4
  1. #1 squirel ate my wiring harness, need help
    SE Level Member sideshow elvis's Avatar
    amarillo texas route 66
    he ate into my 08 grand prix wiring harness to the fuse box. i connected all the wires back, most did not have any tracers, anyway, i can pull off the neg cable on the battery, re install, and the car runs great, kill it, try to start agian, it just clicks. redo the cable thing ,and it starts agian. what is going on? i cleaned the posts, and the cable terminals. re tighten. nothing helps.
    also ,checked all fuses, except large metal fuses that cant be checked ,(i dont think) /// ???
    any help would be appreceated
  2. #2 Re: squirel ate my wiring harness, need help
    Only thing I can think of is double check everything and make sure he didn't chew through anywhere else.
  3. #3 Re: squirel ate my wiring harness, need help
    thanks
  4. #4 Re: squirel ate my wiring harness, need help
    Pennsylvania
    Rattlesnaking you, eh? Um. Hm. Check your grounds?
  1. Do I need a wiring harness?
    By cyclones in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2011, 07:46 AM
  2. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  3. zzp wiring harness
    By TheOtherNick in forum Audio, Security & Visual Electronics
    Last Post: 11-03-2008, 02:47 PM
  4. 04+ Wiring harness
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-27-2008, 03:22 PM
