Quote Originally Posted by Bluedogge View Post
Ok, I will check around the battery tomorrow. If it is a ground problem, I know to check the main ground going from the battery to the block, what other grounds should I be checking? not sure where the others are.
The coil pack bracket ground to the front head.
OR take the boots off one pack at a time and turn the car over to see if it arcs. If it does then the ground should be ok but I would still check it.
