Thread: Pre Top Swap Questions
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Pre Top Swap Questions
    L67 swap it. the whole motor is not only easier, its more reliable. top swapping is a fad.
    the only reason you need a high compression block is if you ran out of room with your L67 setup and are running a 2.4 pulley.
  2. #22 Re: Pre Top Swap Questions
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Ok, Thanks bio. Can I just use the pcm on the gtp for a while then? I have a tuned one for my GT and like it so I figured ill send one in and get it tuned for the GTP. Also does a VS cam need a certain tune also? Ill just wait until get the cam and drop it in before i get one tuned then. What springs would you recommend for the VS cam as well?
    The gtp pcm won't have the correct gear ratio. It'll drive funny and throw a code.
    You'll need a good retune for the cam. I would do everything at the same time so you're tuned for it all.
  4. #24 Re: Pre Top Swap Questions
    Nov 2010
    If I already have a 2.5'' down pipe with a cat. Could i just get a PLOG and run that with a cam? Or do i have to get headers for more flow?
  5. #25 Re: Pre Top Swap Questions
    new britain, ct
    headers.
    07 Black GXP.
  6. #26 Re: Pre Top Swap Questions
    Is turbo the next fad?
    Ohio
    Seems to be going that way
  1. L36 Swap Questions
    By VGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2013, 07:18 AM
  2. Top swap questions
    By killer84 in forum General Tech Discussion
    Last Post: 12-17-2010, 08:28 PM
  3. Gen V Swap Questions
    By jdbaringer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 12:44 PM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
