Thread: 8 rib pulley questions
Results 1 to 12 of 12
  1. #1 8 rib pulley questions
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    going to be doing a pulley drop down to a 3.4 somewhere in the near future. i'm going to have to get a new belt obviously and have been seeing some things about 8 rib pulleys. ive been wondering if theres anything super great about these? basically what are pros and cons to this so that way i may consider doing it.
  2. #2 Re: 8 rib pulley questions
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    More power loss.
    More grip.
    The Boss Iceman6669's Avatar
    Jun 2011
    IIRC they are not needed till you go to a sub 3" pulley...
    2011 F-150 Yote powered
  4. #4 Re: 8 rib pulley questions
    Nov 2010
    Illinois
    K thanks guys
  5. #5 Re: 8 rib pulley questions
    Get a Napa Gates premium belt and look at it... if it looks sparkly inside, like traction tape..that's the belt you want.
    8 Rib is nice, only if you have slip and even then..a wrap kit may be a better way to go.
  6. #6 Re: 8 rib pulley questions
    Donating Users Tengis's Avatar
    Houston
    8 rib setups are kinda pointless. The belt wrap kits make a lot more sense.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  7. #7 Re: 8 rib pulley questions
  8. #8 Re: 8 rib pulley questions
    Nov 2010
    Illinois
    ^^^ are you being sarcastic? lol how would i know if there is slip? and does it happen a lot?
  9. #9 Re: 8 rib pulley questions
    you'd notice it because the needle would bounce in the upper RPMs and the blower would make a funny chirpy whine. you'd also have rubber somewhere (probably the hood and the pulleys).
    and yes, i was being sarcastic. however, the wide belt does look awesome. i plan to run 8 rib and a belt wrap kit, but ill be trying to push as much boost as possible out of the m90.
  10. #10 Re: 8 rib pulley questions
    Nov 2010
    Illinois
    is the belt wrap kit on zzp? i bought a mps system off of someone and he was selling a 8 rip setup for 40 bucks. i was wondering if it really did anything special. so with a 3.4 on there will i eventually have belt slip and need the wrap kit?
  11. #11 Re: 8 rib pulley questions
    Feb 2009
    flintnasty MI
    I like the 8rib balancers.. They are pretty cheap, install is easy and work well with 2.8 pullies.
  12. #12 Re: 8 rib pulley questions
    Nov 2010
    Illinois
    i'll probably never be down to a 2.8 lol i have other toys i want to put my money into plus this is my daily driver.
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. A few pulley questions
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2008, 12:41 AM
  3. Pulley questions
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 09:15 PM
