Thread: Pulley questions
Results 1 to 3 of 3
  1. #1 Pulley questions
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    ok i know this is probably a stupid question for most but i would rather ask . i think my stock pulley is a 3.8 and i am going down to a 3.5 do i would like to know 2 things if possible . first . will i need a smaller pulley belt ? second . what is the rough guess of what kind of power should be seen from drop pulley sizes ? i know there is a chart somewhere on here but i cant find it . thanks for the help fellas .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: Pulley questions
    St. Louis Mo.
    Going from a 3.8 to a 3.5 you will NOT need a smaller belt, I think that comes into play when you dip below a 3.4 I do believe. I think dropping to the 3.5 is like 2-4lbs of boost I think. I am not an expert on the boost to pulley size, I am sure there are others out there that can better answer that part of your question
    James Shafer
    St. Louis MO
  3. #3 Re: Pulley questions
    Donating Users blowfishRus6's Avatar
    g.a.
    i heard 7hp for each . in drop but idk.
  1. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
