Thread: L67 engine block
Results 1 to 20 of 38
  1. #1 Re: L67 engine block
    GT Level Member rolyat's Avatar
    OKC
    Its had a few sets of plugs, couple different sets of wires, and all new coils. No ICM... yet! Lol
    Btw, it does not misfire at all until it starts knocking. So I don't know if maybe misfires are causing the knock or if it is misfiring because of the pcm pulling timing... the later would be my guess.
    A stock pulley would do zero good... it hits 5lbs of boost at half throttle and bam... like 6* of knock. A stock pulley will put out that much boost no problem. I stay out of the boost when I'm just driving. I only get on it when I'm messing with it trying to fix the problem.
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  1. Whole engine block kinda Swap
    By mikeh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-19-2009, 12:30 AM
  2. Engine block
    By slednut in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 08:58 PM
  3. Engine block question for everyone
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 10:14 PM
  4. same engine block?
    By JayGTP02 in forum Off Topic Discussion
    Last Post: 05-06-2009, 09:21 AM
