Thread: Hizzz noise on radiator/smells coolant
Results 1 to 19 of 19
  1. #1 Hizzz noise on radiator/smells coolant
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    I have a '04 GTP and after I got home from work, I heard a hizzing noise on the drivers side of the radiator and it smell like coolant. It never overheated it was just above the half-way mark with the AC off. I don't want to move the car since it might just overheat and then I would have engine problems. Any suggestions on what to do.
    I might also add that when I open the radiator cap (not the reservoir) a bit of coolant spitted out and the hizz noise went away. Could be a bad radiator? Flush?
    Thanks,
    Robert
  2. #2 Re: Hizzz noise on radiator/smells coolant
    check your radiator hoses, they like to break right where the hose goes on the tube to the radiator. look for wetness. and it may only leak when the engines hot, not so much when cold if its the hoses, you also have 2 heater hoses on the pass side behind the alternator. same deal the hose wear out.
    then the plastic elbow off the manifold, water pump, or even the radiator itself could be leaking. you just need to find the wet spot and trace it.
  3. #3 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    it seems that's it's right above the radiator where's it's leaking, where the upper hose it's connected.
  4. #4 Re: Hizzz noise on radiator/smells coolant
    could be the hose or the tube to the rad leaking, let it get hot and move the hose around to see if you can make it leak. at least thats the easy one to change. lol
  5. #5 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    I'm attaching some pics, hope this helps out... or actually me LOL.
    [IMG]/Users/protoncomputers/Desktop/SDC11890.JPG [/IMG]
  6. #6 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    here are some pics, that might help you decide for me what it is..lol
  7. #7 Re: Hizzz noise on radiator/smells coolant
    pic fail.
  8. #8 Re: Hizzz noise on radiator/smells coolant
    looks like its spraying onto the hose. i'd take the mount apart there and see if its rusted or worn through the radiator.
  9. #9 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    you got any instructions on how to take of the mounts?
    what should I'll be looking for?
  10. #10 Re: Hizzz noise on radiator/smells coolant
    Pretty sure it's just a 10mm bolt or two. Turn then counter clockwise.
  11. #11 Re: Hizzz noise on radiator/smells coolant
    Yoga city
    i had soemthing of this nature happen to me. ended up being the nipple where the hose goes on was cracking. i.e. the raditator. i drained sanding the area cleaned and jb weld to the rescue has been great for the past year with no problems
  12. #12 Re: Hizzz noise on radiator/smells coolant
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    From what i can see in the pictures, your hoses dont look to good, maybe its just dirt.
    and those mounts, i don't believe they come off, they are 10mm like bill said but they sit on there.
    I thought once you pulled the bolt you could just rotate them
    I'm not to sure though, as i was going to remove it, but then realized i didnt need to after i got the bolts off.
  13. #13 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    today was my day off from work...so, I took out the mounts and loosen up the fans to see where the leak was happening..so here are the pics... any suggestions, should I still use the JB or should I just buy a new radiator???
  14. #14 Re: Hizzz noise on radiator/smells coolant
    so its leaking from the ends of the fins? if so get a new radiator.
    and whats all that copper looking stuff? bars stop leak? because it looks like barrs leak copper head and manifold repair stuff.
  15. #15 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    it was some type of stop leak I bought at a local AutoZone... I really didnt' want to buy a new radiator...
    oh well...I guess I'll have to now...
  16. #16 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    you got a good place on the internet???... you know low price/good quality..
  17. #17 Re: Hizzz noise on radiator/smells coolant
    junk yards are cheap priced if your on a tight budget.
    i haven't priced one but it cant be over 100 i would think for a new one.
    oh and flush your coolant, get that stuff out of your engine, before you get a new radiator installed, you dont want to clog up the new one with anything.
  18. #18 Re: Hizzz noise on radiator/smells coolant
    Mar 2012
    Edinburg, TX
    what's the EOC and the TOC?? can you help?? before I buy this radiator for 86 dls
    Brand New 1 Row w/o EOC w/ TOC Replacement Radiator For 3.4 3.8 V6 GAS
    • Technological Specification:
    • Vehicle Notes:
    • Core Size (in) approx:: ALUM (30-1/4 x 14-5/8 x 5/8) - 1 Rows.
    • Tank:: PLASTIC
    • Weight (lbs) approx:: 10
  19. #19 Re: Hizzz noise on radiator/smells coolant
    SE Level Member 2000gtpbt's Avatar
    Mar 2012
    Alexandria, MN
    ECO means engine oil cooler and TOC stands for transmission oil cooler. Thats looks right for your car. You get what you pay for remember that, and try amazon I get stuff off of there never had a problem.
  1. oil smells like gas
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2011, 07:48 PM
  2. coolant problem and radiator
    By colindunn in forum General Tech Discussion
    Last Post: 06-01-2010, 12:24 AM
  3. oil is overfull and smells like gas???
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2010, 02:58 PM
  4. Smells like FIre
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 07:06 PM
  5. Bubbles in coolant/ radiator
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2009, 12:27 PM
