Thread: Pin Piont The Leak ?
Results 1 to 20 of 21
  1. #1 Pin Piont The Leak ?
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    I am trying to find out where this leak is coming from the places that i already have veirfied that it is not leaking from are
    A. Oil Pan Gasket
    B. Valve Cover Gasket
    c. Anything that is in the block or oil pan
    *Now a few months back ago a shop skipped over the front seal, and i went back and told them to fix it so they did and now all the sudden it is starting to leak under my car again ?? maybe they didn't fix it right ?? or at all just did a quick fix.
    Well i washed the underbody so that i could find out where the leak is coming from so here is a few pics of where it is coming down from and maybe someone on here can help me out
  2. #2 Re: Pin Piont The Leak ?
    PA
    This looks like it is on the back side of the passenger side of the engine? Is that correct? If so, I am thinking Oil Pressure Sending Unit.
    But could be front main seal. If that is the case, take it back to the monkeys that was supposed to fix it before.
    2001 GSE
  3. #3 Re: Pin Piont The Leak ?
    St. Louis
    Yup your right front passenger side, yea i think i am going to have to and maybe tell them that i plan on staying up there and watching them fix it this time, .......... shops
  4. #4 Re: Pin Piont The Leak ?
    Wichita, KS
    Leaks can suck to find, but if you trace it, using gravity as your guide, you can find it easily.
    In your case, I would say you need to check the oil filter elbow where it bolts to the front engine cover very well. It could be cracked/damaged or your sender is leaking by etc.
    ~F~
  5. #5 Re: Pin Piont The Leak ?
    St. Louis
    me and gravity aren't getting along right now checked the oil filter elbow where it bolts to the front engine cover very well along with the sender, both clean as can be. A little update that i forgot to add it does it while just sitting, but i am pretty sure that could have been a given and i am oped to say that it would have to be the front main because i have already lost probably quarter of a quart...
  6. #6 Re: Pin Piont The Leak ?
    St. Louis
    valve cover maybe? i just found this out... the whole rear part of the block is covered in oil also and here are a few pics not the best but it is hard to take a good picture with a DP in the way
    but i didn't think that a vale cover could just leak out like that
  7. #7 Re: Pin Piont The Leak ?
    PA
    Quote Originally Posted by stlmo_gtp View Post
    Valve cover was my first thought actually. But you said you had ruled it out:
    A. Oil Pan Gasket
    How did you "verify" previously that it was not leaking here? Because it looks like it is. And yes, they can leak pretty aggressively if bad.
    2001 GSE
  8. #8 Re: Pin Piont The Leak ?
    Wichita, KS
    Regardless...you need to change the valve cover gasket, and clean the area well after your done.
    I would take it to a power washer and get all the oil off you can.
    If your loosing THAT much oil then thats a pretty big leak.
    If it were your front main seal, then your balancer would be throwing oil as the engine runs, regardless if it only leaks when sitting. Some would still get on it.
    If you think its the front main seal, then reach up and feel behind the balancer, if its really wet, then you may be onto something.
    I have seen valve covers leak, but never THAT bad where you loose as much oil as you say you are.
    ~F~
  9. #9 Re: Pin Piont The Leak ?
    Bastard Reptile's Avatar
    Kansas City, MO
    It still might not hurt to pull the balancer to inspect it if all else fails. Are all of the bolts in the oil pan on that side of the engine? There should be 3 that hold the pan to the front cover. you can check by running your fingers along the edge of the pan to feel for them.
  10. #10 Re: Pin Piont The Leak ?
    St. Louis
    working on it now will post back, but i have gotten the rear valve cover off i just can't get it out for some reason, but from just feeling i ask myself "rear valve cover gasket ?? it's missing???"
  11. #11 Re: Pin Piont The Leak ?
    Kansas City, MO
    The rear can be a total pain. Sometimes when you take the cover off, it immediately drops down the backside of the head on that back side. Some of it should still be stuck in the cover though.....but if you don't have a gasket, it'll leak like a sieve.
  12. #12 Re: Pin Piont The Leak ?
    St. Louis
    yea odd that when i ran my fingers across that i felt nothing... so this could be my problem right here
  13. #13 Re: Pin Piont The Leak ?
    PA
    It could also be so compressed that you don't feel it. If it wasn't there, you would feel the .25" groove around the valve cover.
    2001 GSE
  14. #14 Re: Pin Piont The Leak ?
    St. Louis
    i feel a grove up into the cover if you know what i mean...? it's hard to explain, i am waiting for this rain delay to be over so i can get back to it
  15. #15 Re: Pin Piont The Leak ?
    Kansas City, MO
    If the gasket were in there, even compressed you should feel it. It sounds like someone neglected to put one in. Could have started a fire for one thing.
  16. #16 Re: Pin Piont The Leak ?
    St. Louis
    yea or the last joe blows shop that worked on it wanting to make sure that it came back... ?? who knows
  17. #17 Re: Pin Piont The Leak ?
    Wichita, KS
    A shop works on your car, they were back there messing around and had the cover off, you now have a leak, there is no gasket...
    I'd be pissed.
    ~F~
  18. #18 Re: Pin Piont The Leak ?
    St. Louis
    well it was the valve cover gasket FTW, it was on there just not all there. And the bolts to the cover werent even tight, so i fixed the problems and now i am back to leak free.
  19. #19 Re: Pin Piont The Leak ?
    Kansas City, MO
    Good to hear!
  20. #20 Re: Pin Piont The Leak ?
    St. Louis
    yea it is a great relief to come out and see no spots on the driveway
  1. A/C refrigerant leak
    By m0ng00se in forum General Tech Discussion
    Last Post: 04-15-2010, 10:15 PM
  2. fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2008, 03:40 PM
  3. masive oil leak
    By AKGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2008, 09:40 AM
  4. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
  5. Oil leak problem
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 05:24 AM
