Thread: Driver window issues
Results 1 to 5 of 5
  1. #1 Driver window issues
    SE Level Member Cummins97's Avatar
    Sep 2011
    Missouri
    Window hasn't worked since the day I bought it.
    I assumed it was a regulator, so I bought one and went to install it today. I removed the old regulator and as with every part I remove I like to test and double check the part to see if its bad (unless its obvious lol). Well I hooked 2 wires to the battery and then to the regulator motor. Low and behold the dang thing works great. So I went wire testing and found it has power to the switch, (not sure of the wires that had power but I can find out if needed). I pushed the down button and tested the plug that goes into the reg motor. Both wires had power (one had 11.8 ish and the other has 12.2 ish)? When the up button is pushed there is no power to either wire at the motor plug.
    I'm thinking it's a bad switch what do you guys think?
    Do I need to do more testing?
  2. #2 Re: Driver window issues
    Sep 2011
    Copperas Cove, TEXAS
    Bad switch, dealt with this 3 weeks ago. $17 later from a junk yard and problem fixed. Too easy!!!
  3. #3 Re: Driver window issues
    Sep 2011
    Missouri
    Great, that's what I was thinking. Thanks for confirming!
    Sep 2011
    Missouri
    Update: it was the switch. Thanks guys!!
  5. #5 Re: Driver window issues
    Sep 2011
    Good stuff, your welcome.
  1. Driver side window
    By Wings672 in forum How To Write-Ups/Tech Tips
    Last Post: 05-26-2010, 04:42 PM
  2. Can't put driver's side window up!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 04-12-2010, 12:50 PM
  3. Hud and driver window issues
    By tjhgtp86 in forum Audio, Security & Visual Electronics
    Last Post: 03-21-2010, 06:43 PM
  4. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
