Thread: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
Results 1 to 9 of 9
  1. #1 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    Cambridge, WI
    I have a 2002 Grand Prix, and I noticed today underneath the fuse block under the hood there is a wire connection that is not connected to anything. It has a brown and green wire. Any ideas what this is for? And more importantly where does it connect to?
    Photo attached.
    2002 Grand Prix - brown/green wire under hood, below fuse block.  What is it? Attached Images
  2. #2 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    Portland Oregon
    You got me stumped. That's a 3 pin connector with two wires on it. I was originally gonna say wheel speed sensor for that side because they plug into another run of cable that goes down to the sensor but they definitely use a 2 pin connector.
  3. #3 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    is your windshield wiper fluid tank gone or maybe was unplugged
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    Cambridge, WI
    The windshield wiper fluid tank/pump is located further down inside the wheel well. I've confirmed that the pump is connected. So that's not it. I've searched the entire passenger side of the car and have not found the connector that it is supposed to plug into.
  5. #5 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    low washer fluid sensor ?
    1997 Red GTP 182000 miles stock
  6. #6 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i just went outside and checked. it could be low windshield fluid sensor. the plug goes into another connector that has wires going from that down towards the pump RIGHT next to the battery. so look on the other side of the battery where those other wires by the connector are going. if you need a picture i'll take one and upload it.
  7. #7 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    Oct 2012
    Beacon, NY
    Hmmm, why is your windshield fluid tank down by your wheel well? I have an 02 GP too and my fluid tank is right next to my fuse block. What GP do you have/ SE, GT or GTP? Are you the original owner? That's strang that it's down by your wheel well though.
  8. #8 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    Houston
    It's probably for an option that you don't have. Tape it up. If you must know what it's for, ask BillBoost. Im thinking it may be a connector for an optional block heater.
  9. #9 Re: 2002 Grand Prix - brown/green wire under hood, below fuse block. What is it?
    Oct 2012
    Beacon, NY
    Actually, I lied. I was just outside looking at my fuses and my windshield fluid is by the wheel well also. On the other hand, right next to my fuse block is my battery. In your picture there is a big gap between your belt system and battery (i believe). Which is strange because i do not have a space like that.
  1. Brown 2002 Grand Prix GT(need help with mods)
    By Canucks4LIFE in forum Members Rides
    Last Post: 12-12-2011, 02:07 AM
  2. Green Grand prix
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 11-10-2009, 06:31 PM
  3. fuse block ?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:09 AM
  4. 04 Grand Prix Fuse Block map
    By btempelman in forum General Tech Discussion
    Last Post: 03-15-2009, 03:38 PM
