Quote Originally Posted by Drews View Post
the elbows fine and there isnt any play i the pulley but theres definaely some coolan under the pulley snout.... how would i go about fixing? new water pump?
yup its a easy fix. remember to break the 4 bolts on the pulley loose first before you take the belt off. the 4 long bolts you need to clean them up some and slap some thread sealer on the treads, they go right into the block into a coolant passage. coolant will leak out when you remove these bolts. also make sure all the old gasket is removed or it will leak.
looks like this off.
and like this with a new one on.
