So after spraying carb cleaner around i think i found my vac leak that is screwing with my fuel trims. the supercharger gasket i got when i did my gen v swap 2 months ago is splitting apart in front corner by the snout. Idle changes when i spray there so i know there's a leak but the guy at the dealership told me those supercharger gaskets dont usually fail like that and he thought the supercharger i got could be warped or off plane. Going to be checking tomorrow either way but which do you guys think is more likely? Its a felpro i believe if that matters
