Thread: bad supercharger gasket?
Results 1 to 14 of 14
  1. #1 bad supercharger gasket?
    May 2011
    iowa
    So after spraying carb cleaner around i think i found my vac leak that is screwing with my fuel trims. the supercharger gasket i got when i did my gen v swap 2 months ago is splitting apart in front corner by the snout. Idle changes when i spray there so i know there's a leak but the guy at the dealership told me those supercharger gaskets dont usually fail like that and he thought the supercharger i got could be warped or off plane. Going to be checking tomorrow either way but which do you guys think is more likely? Its a felpro i believe if that matters
    1969 chevelle - project car
    2004 Impala SS - Gen V, 3.6 pulley, w-body store headers, SLP power flo catback, 180*, CAI, Northstar throttle body, ported lower intake, intense pcm, egr delete, 104's, zzp strut tower braces, Quad tail light mod, more to come.
  2. #2 Re: bad supercharger gasket?
    Its possible.
    Id blame an install error for this to happen. Uncleaned surface or the gasket got tweeked before install.
  3. #3 Re: bad supercharger gasket?
    May 2011
    iowa
    im guessing surface wasnt perfect but its spitting on the gasket at a point that isnt under the supercharger just one of the parts that sticks out
  4. #4 Re: bad supercharger gasket?
    I wasn't aware Fel Pro had a Gen V gasket out there yet. Got a part number?
    I'd use the GM metal gasket with inlaid rubber and plug the coolant ports if they are the recessed ones.
  5. #5 Re: bad supercharger gasket?
    May 2011
    iowa
    It was just a gasket from the dealer looked like a Felpro gasket may not have been. It wasn't metal it was a paper type gasket like the gaskets for the l67 throttlebody where do i get a metal gen v gasket?
  6. #6 Re: bad supercharger gasket?
    Part numbesr
    http://www.grandprixforums.net/common-part-numbers-pulleys-goops-gaskets-39796.html
    There are only two gaskets I'm aware of. A fiber type one with metal inside it and the o-rings are integral to it. Then there's the metal one. The difference depended on when your LIM was made. If the coolant ports were recessed, then it got the fiber one, if they weren't, it gets the metal one.
    Fiber
    metal
    However if you block the coolant ports. You can use the metal one on either. The fiber one..is not an equal to the TB gasket, it was different than any standard paper gasket I've used.
  7. #7 Re: bad supercharger gasket?
    May 2011
    iowa
    no idea when it was made but coolant ports are blocked off so it doesnt matter i guess. so 12584411 is that part number for the gen v aluminum gasket? Do i need to use silicone under it on top of the lower intake to get a better seal or is it not recommended?
  8. #8 Re: bad supercharger gasket?
    It's a dry install.
  9. #9 Re: bad supercharger gasket?
    May 2011
    iowa
    is that the correct part number for the metal gasket?
  10. #10 Re: bad supercharger gasket?
    It's listed in the common part number thread.
    here's a pic to help confirm it
  11. #11 Re: bad supercharger gasket?
    May 2011
    iowa
    ok ya i saw it i was just making sure it was correct thanks ill pick one up today and see if it helps
  12. #12 Re: bad supercharger gasket?
    Kinda silly for me to post it if it's the wrong number. I double checked all those part numbers before putting that together. Order with confidence.
  13. #13 Re: bad supercharger gasket?
    May 2011
    iowa
    wasnt doubting you, just measuring twice and cutting once so to speak lol
  14. #14 Re: bad supercharger gasket?
    People like you hinder the JB Weld sales numbers.
  1. Supercharger Gasket
    By RideMr2 in forum General Grand Prix Discussion
    Last Post: 01-29-2012, 02:12 PM
  2. Best way to clean LIM & supercharger gasket surfaces?
    By Elite6 in forum General Tech Discussion
    Last Post: 12-01-2011, 07:15 AM
  3. Supercharger gasket
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2011, 03:48 PM
  4. Supercharger Gasket
    By Spazztic2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-17-2010, 02:47 PM
