Thread: Sticky Gas pedal? Help!
Results 1 to 7 of 7
  1. #1 Sticky Gas pedal? Help!
    Jun 2010
    winston-salem
    Hello everyone, most of the time when I go to start my GP, i either have to "un-stick" the pedal by pressing it down before I start the car or push it down and jerk the car forward to unstick it once started. To be more specific, the pedal just gets stuck and is hard to press down, but once I give it a little force it works fine and doesn't stick while driving. It just gets hard to press down after cutting the car off for extending periods. Once i unstick it then its fine while driving. I suspect a gunky throttle cable, or dirty throttle body? Any ideas what it is, and suggestions to fix it? Mind you its the original throttle cable and linkages from 1998.
    thanks
  2. #2 Re: Sticky Gas pedal? Help!
    Grand Rapids, MI
    Ever cleaned the TB? Perhaps the throttle plate is filthy. Good luck finding it
  3. #3 Re: Sticky Gas pedal? Help!
    GT Level Member Pontiac Man's Avatar
    Sep 2011
    Decorah IA
    My 01 did that, I could not find the problem. I lubed as much of the throttle cable as I could but did not fix it.
  4. #4 Re: Sticky Gas pedal? Help!
    Jun 2010
    winston-salem
    Ok, i'll try the throttle body and cable b'c neither has been touched since i've had the car so lets see how that works out
  5. #5 Re: Sticky Gas pedal? Help!
    I had a dodge daytona that did this but it would stick at WOT sometimes as well. Pulled the tb off and it had grooves it in where the blade wore into it. It had about 350,000-400,000 miles on it though.
  6. #6 Re: Sticky Gas pedal? Help!
    pop the cable off the throttle body and push the cable back in and pul it back out of the cable housing, see if its smooth, they do fray up and cause sticking. and then break.
  7. #7 Re: Sticky Gas pedal? Help!
    Charles City, IA
    I would say dirty throttle body.
    SMGPFC Two Nipple General
  1. sticky take off
    By 94grandprix in forum General Tech Discussion
    Last Post: 03-25-2011, 11:45 AM
  2. sticky this please
    By BoostJunki3 in forum Tires & Wheels
    Last Post: 03-21-2010, 02:44 PM
  3. Sticky gas pedal
    By VGPGT in forum General Tech Discussion
    Last Post: 03-03-2010, 06:40 PM
  4. sticky shifter?
    By bigredv65 in forum The Rant Forum
    Last Post: 02-04-2010, 10:54 PM
  5. sticky gas pedal
    By johnnyj773 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 05:00 PM
