Thread: jb weld heat tolerance?
Results 1 to 13 of 13
  1. #1 jb weld heat tolerance?
    Jacksonville, Fl
    so i had my pacesetters tack welded and thats coming back to bite me in the arse. i didnt expect to ever have to replace my motor though after rebuilding it... i ended up using a grinding stone to get it off since a hammer and chisel wasnt working and i couldnt fit a cutting wheel into the space. i ended up grinding a little too much off. the pipe is still sealed but it is thinned now. i was wondering if i could just put in some jb weld to fill it in. would it hold up to the heat? its located on the back end of the crossover pipe entering the down pipe.
  2. #2 Re: jb weld heat tolerance?
    I wouldnt do that.
  3. #3 Re: jb weld heat tolerance?
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    my racebike had a crack in the outside of the water jacket for the cyliner head. jb weld did the trick and i raced it again with no issues.
    J-B Weld Company - J-B WELD Product Information
    this says 500 degrees
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  4. #4 Re: jb weld heat tolerance?
    I used jb weld on my bikes carbs and exhaust and it's holding just fine a year later.
  5. #5 Re: jb weld heat tolerance?
    Oct 2011
    Toledo, OH
    Don't use JB Weld. They make a special kind of stuff for exhaust. Can't remember what its called but I used it to seal an EGR tube on a Fiero once. Looked like liquid glitter and was good for 2000 degrees or so.
    7"
  6. #6 Re: jb weld heat tolerance?
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    There might be some better stuff out there. Jb won't hurt if it doesn't work. Just give it AT LEAST 24 hours to set.
  7. #7 Re: jb weld heat tolerance?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    tho only problem I see is the jb wel not having enough to grab onto its like putting a bandaid on a leaking water pipe, if I did it I would go all the way around that section of the header with it to give it more strength
  8. #8 Re: jb weld heat tolerance?
    Jacksonville, Fl
    Quote Originally Posted by industrialfish View Post
    sounds like liquid magic. ill look into that stuff. like i said, the exhaust is still sealed. just wanted to make sure it stayed that way
  9. #9 Re: jb weld heat tolerance?
    Kansas
    Pretty sure he was talking about this stuff.
    http://www.amazon.com/Permatex-80697.../dp/B000HBNUDQ
  10. #10 Re: jb weld heat tolerance?
    Jacksonville, Fl
    thats only tolerant to 500 degrees down in the notes. ive read jb weld is tolerant to 600
  11. #11 Re: jb weld heat tolerance?
    Kansas
  12. #12 Re: jb weld heat tolerance?
    Jacksonville, Fl
    awesome. ill definitely pick some of that up
  13. #13 Re: jb weld heat tolerance?
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    I used it to fix the a crack in the exhaust manifold on my 78 plymouth volare after I ground the crack a little wider and it worked awesome.
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  1. Cracked Rim..Weld or Buy New Rim?
    By illtacticz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2012, 07:29 PM
  2. How much tolerance in coupler on S/C?
    By SnowDrift in forum General Tech Discussion
    Last Post: 09-30-2011, 11:38 AM
  3. Jb weld on radiator?
    By jteske88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2011, 12:25 PM
  4. Did you have to weld your headers for your 3800?
    By Lawngoose in forum Off Topic Discussion
    Last Post: 08-12-2010, 12:16 PM
  5. I'd like to learn how to weld!
    By Quicklynx in forum Off Topic Discussion
    Last Post: 12-08-2008, 10:11 PM
