Thread: How much tolerance in coupler on S/C?
Results 1 to 14 of 14
  1. #1 How much tolerance in coupler on S/C?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Does the coupler on the S/C snout fit tight against the guide pins? I have a tiny amount of movement in mine that I can hear when I rock the pulley back and forth. No rocks sound yet, no other issues, but I guess I'm thinking that if it is on its way out, now is a good time to address the issue.
  2. #2 Re: How much tolerance in coupler on S/C?
    should be very snug on there, like zero movement.
  3. #3 Re: How much tolerance in coupler on S/C?
    If it hasnt been replaced I would just replace it.
  4. #4 Re: How much tolerance in coupler on S/C?
    if you can feel it has play in the shaft, the coupler is on its way, mine had a pins width of wear in both directions of the original center hole, made a good racket at idle.
    new is real tight, no play in it at all. got mine off e bay for 21 bucks shipped or so.
  5. #5 Re: How much tolerance in coupler on S/C?
    Apr 2009
    Thanks guys. I kind-of thought that. I'd rather do it now, than when I need it to be done, and it is really bad.
  6. #6 Re: How much tolerance in coupler on S/C?
    Dont forget to get supercharger oil.
  7. #7 Re: How much tolerance in coupler on S/C?
    Apr 2009
    Yes, thank you. I have one bottle, but will pick up another
  8. #8 Re: How much tolerance in coupler on S/C?
    when putting new couplers in..I have found that the pulley is tough to turn by hand at first. It'll loosen up with a little oil splash and the engine turning it.
    Just an FYI so you don't freak out when you swap it.
  9. #9 Re: How much tolerance in coupler on S/C?
    Apr 2009
    Great information. Thanks Bill.
    Coupler just sits there, right? No fasteners.
  10. #10 Re: How much tolerance in coupler on S/C?
    Correct
  11. #11 Re: How much tolerance in coupler on S/C?
    Apr 2009
    Just learned Intense Racing is about 45 minutes from me. I think I might have to make a road trip...
  12. #12 Re: How much tolerance in coupler on S/C?
    Tell Todd I said hello.
  13. #13 Re: How much tolerance in coupler on S/C?
    Apr 2009
    Todd isn't with them anymore, as I learned last night. New ownership under John. In talking with him, I think the company is moving in the right direction. The John brings great honesty and integrity with him, which should really grow the company.
    Seal is in, new coupler is in and I have one more pulley to change out as soon as I have a chance and I'll be back to having a GTP instead of my GT.
  14. #14 Re: How much tolerance in coupler on S/C?
    Denver
    When I replaced mine I was skeptical it was causing the rock-tumbler noise coming from my snout. The stock coupler had a little play and I didn't believe it could be responsible for such noise. I was expecting giant egg-shaped holes when I first cracked it open.
    I was quickly proven wrong.
    The pins should be a slip fit (like .0001" clear) with basically zero movement. If you can see any daylight between your pin and the coupler hole, your coupler is shot.
  1. S/C Coupler not right??
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 07-25-2012, 11:45 PM
  2. Bad coupler?
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2010, 06:08 PM
  3. SC Coupler
    By JB381 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2010, 07:15 PM
  4. Which coupler?
    By karkrazy1971 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 02:40 PM
