Thread: Changed the Ambient Temp Sensor...Still not right.
Results 1 to 5 of 5
  1. #1 Changed the Ambient Temp Sensor...Still not right.
    GT Level Member Peacher213's Avatar
    STL Metro Area
    The sensor was reading mid 40's on an 80 degree day. So I swapped out the sensor, and after driving around for a few minutes..It came up to 55 degrees. Its still in the upper 70's outside. What gives?
    And will this effect the A/C this summer?
  2. #2 Re: Changed the Ambient Temp Sensor...Still not right.
    warranty it out, and if its still bad, then you got other issues.
  3. #3 Re: Changed the Ambient Temp Sensor...Still not right.
    Saw similar and dug into the issue on my current crapbox. IIRC 40 something is the default when the sensor takes a dump. If you swapped it out and see just a little different reading, check the wiring. Mine had been abused somehow and moving it fixed the issue temporarily.
    It's been two years now.. one of these days I'll pull out a new pigtail and solder. Right...you heard it.
  4. #4 Re: Changed the Ambient Temp Sensor...Still not right.
    STL Metro Area
    Well, it seems to be working now. If it messes up, I'll inspect the wiring. Thanks.
    99 GTP coupe
    Stock, other than open cone filter.
  5. #5 Re: Changed the Ambient Temp Sensor...Still not right.
    We are in the same boat. Rock on... don't look or fix them til it goofs up again.
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. ambient air temp sensor
    By Toasty in forum General Tech Discussion
    Last Post: 09-10-2011, 10:12 PM
  3. 95 GTP Ambient Air Temp Sensor
    By ztsmith86 in forum General Tech Discussion
    Last Post: 08-17-2011, 09:21 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
