Thread: Sunroof only moves a fraction of an inch per press
Results 1 to 14 of 14
  1. #1 Sunroof only moves a fraction of an inch per press
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    2004 GT2. This has happened intermittently all summer, but now that it's cooling off it's constant. When I open the sunroof or close it, it only moves 1/2" to " per press of the switch. I'm not really sure what to check for this issue. It clicks and moves then clicks and stops. The switch feels normal.
    I seem to remember reading somewhere where a person had fixed a similar issue with a hard drive magnet, but I can't find the reference and have hard drive magneted the $hit out of it and had no luck :P.
    Ideas?
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  2. #2 Re: Sunroof only moves a fraction of an inch per press
    Ocala, FL
  3. #3 Re: Sunroof only moves a fraction of an inch per press
    Nov 2010
    West Fargo, ND
    Yeah, that's the one. I just went out there and spent some more time trying it-- no love. I don't feel a tug anywhere either. .
  4. #4 Re: Sunroof only moves a fraction of an inch per press
    I'm not seeing what a magnet would do to the sensor. Unless it pulls it down or something.
  5. #5 Re: Sunroof only moves a fraction of an inch per press
    Nov 2010
    West Fargo, ND
    It didn't seem to do anything in my case. I pulled down the console again, and there's nothing on top of it that would seem to be related. I moved the magnet around above it too, and no love. Meh.
  6. #6 Re: Sunroof only moves a fraction of an inch per press
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    mine does the same thing im taking it to the dealer and letting them dealing with it
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  7. #7 Re: Sunroof only moves a fraction of an inch per press
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    Quote Originally Posted by cliffdawg View Post
    mine does the same thing im taking it to the dealer and letting them bend me over and take all my money
    fixed
  8. #8 Re: Sunroof only moves a fraction of an inch per press
    Mar 2012
    VIRGINIA
    I'm having the same issue with my sunroof, it moves in little spurts everytime I press the switch. Is this the same symptoms you had ? If so, can you tell me what the problem was and what the dealer did to fix it?
    Thanks
  9. #9 Re: Sunroof only moves a fraction of an inch per press
    Mar 2012
    VIRGINIA
    What was the fix?
  10. #10 Re: Sunroof only moves a fraction of an inch per press
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Quote Originally Posted by ANGUS YOUNG View Post
    What was the fix?
    Interested too! Mine sometimes will stop only halfway open.
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  11. #11 Re: Sunroof only moves a fraction of an inch per press
    Jersey
    subscribed
    16' wrx sti- stock
  12. #12 Re: Sunroof only moves a fraction of an inch per press
    GTP Level Member joshv's Avatar
    canada
    clean the track it runs on and re-grease it, its just not slippery any more and its getting stuck, happened on my 04
  13. #13 Re: Sunroof only moves a fraction of an inch per press
    Nov 2010
    West Fargo, ND
    I wiped off the stiff old grease, greased the track with some moly grease that I had in the garage, and used some chain lube on the springs on the side. It might be a little better, but I'll work it some more tomorrow when the sun is out. Assuming it comes out.
  14. #14 Re: Sunroof only moves a fraction of an inch per press
    Nov 2010
    West Fargo, ND
    It's not fixed... I tried lubing the tracks with some grease, and it didn't make any difference. Now that it's warmed up a bit it's better. The only thing that has helped at all was using some silicone spray on the tracks, so it opens without any problem now, but still stops every couple of inches while closing it. I did wipe most of the grease off of the tracks before this-- maybe the moly grease was too "stiff" to allow it to glide smoothly? At any rate, closing it is still an exercise in frustration...
  1. speedometer moves when revved
    By shawnschuldt in forum General Tech Discussion
    Last Post: 10-09-2011, 10:22 AM
  2. Car moves 200 feet, won't move further until restarted
    By darkfox1009 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2011, 11:13 PM
  3. 94 Grand Prix speedo moves with signal flash
    By AMXTRA in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-21-2010, 12:36 AM
  4. flanging from 2.5 inch downpipe to 3 inch exhaust?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 07:44 PM
