Thread: speedometer moves when revved
Results 1 to 12 of 12
  1. #1 speedometer moves when revved
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    When I revv my car the speedometer moves and the hud also shows me moving. If I hold it at 5k it shows I'm going 10 mph. My right front speed sensor is bad can this cause it or is it in the tranny
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #2 Re: speedometer moves when revved
    Donating User Odi's Avatar
    Chicago South Suburbs
    Quote Originally Posted by shawnschuldt View Post
    you answered your own question
  3. #3 Re: speedometer moves when revved
    Florida
    dood, your car is just that badass!
    Also, see the above statement...^^
  4. #4 Re: speedometer moves when revved
    Buffalo
    I've noticed that in a few of the regals around here. Just give it some hard quick revs and the spedo moves a bit
  5. #5 Re: speedometer moves when revved
    Jun 2010
    Beloit, WI
    i didnt know if the speed sensor in the hubs could cause this, because i always understood the actual speed thats displayed on the speedometer and hud came out of the tranny.
    --00 Red GTP--
    13.07@108mph
  6. #6 Re: speedometer moves when revved
    bill once told me it was the vss sensor near the differential that needs to be either removed and cleaned or replaced.
  7. #7 Re: speedometer moves when revved
    GT Level Member sic6's Avatar
    san marcos, tx
    The abs sensor should not affect the speedometer reading. I would do like Matt stated or also check the wiring going to the sensor itself.
    97 GTP
  8. #8 Re: speedometer moves when revved
    Jun 2010
    Beloit, WI
    What has to be done to get to it?
    --00 Red GTP--
    13.07@108mph
  9. #9 Re: speedometer moves when revved
    Florida
    Nothing really, though if you take the dogbones out, and rock the engine forward and lock it, it'll give you more room. Just look down by the power steering from the top, and you'll see it.
    When I removed it (the connector was glued in, wtf?) I read that you had to install a new o-ring, or it could mess with the sensors accuracy..so thats what I did. I think it's held in by a 10mm, but it's been ages.
  10. #10 Re: speedometer moves when revved
    Jun 2010
    Beloit, WI
    im going to pull it tomorrow any idea where to get the o-ring, and i did notice last night when i was in the car wash when the high pressure went by that right front wheel it would make my speedometer move
    --00 Red GTP--
    13.07@108mph
  11. #11 Re: speedometer moves when revved
    Florida
    Then thats not good....Cause if it is that sensor being loose/broken, that means tranny fluid can leak, and water can get in...
    When I did mine, i pulled the sensor, and then ran up to a parts house to size it (in a different car, of course)
    So I dont know it off the top of my head, but a good o-ring assortment should have the right size.
  12. #12 Re: speedometer moves when revved
    Jun 2010
    Beloit, WI
    im hoping its going to be in the plug or something because i agree on the water thing but i have changed my fluid and filter a couple times now and there is no sign of water.
    --00 Red GTP--
    13.07@108mph
  1. Car moves 200 feet, won't move further until restarted
    By darkfox1009 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2011, 11:13 PM
  2. Speedometer help
    By ElAlacran2010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2011, 10:55 PM
  3. Noise when revved
    By dengnath in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-31-2010, 02:47 PM
  4. 94 Grand Prix speedo moves with signal flash
    By AMXTRA in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-21-2010, 12:36 AM
  5. 2006 GXP Driver seat moves when engine turned off
    By ponyfool in forum General Tech Discussion
    Last Post: 03-06-2010, 12:14 PM
