^^^^^^^^ Could try that or swapping coils to see if the miss fire changes cylinder number too.
I have never in my life seen fuel injector cleaner do a thing as far as having a misfire light on waste IMO.
Miracle in a bottles are 90% the time a joke.
wouldnt a clogged cat problem get worse under load as the cars trying to get rid off more exhaust rather than idleing nope doesnt seem like an exhaust problem to me either.
Missfire still makes me believe its in the ignition system..............
were the spark plugs and plug wires replaced as an attempt to fix your #3 misfire or did the misfire occur after installation of the new parts? Exactdy what was missing from the spark plug? Was it the end that goes into the spark plug wire boot or the end that goes into the engine?
not really maybe a little bit would a cat make it misfire on one cylinder?
Dude im not trying to argue with you so chillax,
If your actually driving its producing more exhaust than at idle and it was already stated that the car runs worse at idle so problems at a lower rpm rather than actually driving the car would make me highly doubt its anything to do with the exhaust.
btw a bad cat would likely cause RANDOM misfire across all the cylinders rather than just one trust me ive had a 02 with a bad cat and it was throwing egr codes too and it was getting super hot.
An electrode missing from a spark plug makes me worry...hope you didn't toast a valve, or worse.
You may need to take that car to a professional.
IM NOT A SHE AND THEY WONT LET ME CHANGE MY NAME.... but the new one is ok still no damage
The old one was damaged...correct?
toast a valve or something geezus christ people dont you read the thread !? it runs fine except at idle!
Cmon this cant be that hard I still say its ICM or at the very least ignition system related its throwing a misfire code lol why would the code lie to you!
it was damage but not sure if it happened when it fell down the front of the motor it doesnt burn any oil and its only a misfire at idle
it had a radom misfire then i changed plugs and wires then i got a code for number 3 misfire so i changed coil pack but still there
I wasn't aware of a code that says "random misfire only at idle". What number is that?
P0300
You mean P0303? This would indicate cylinder number 3.
A bad ICM CAN screw up one cylinder!
here is an idea grab the socket and ratchet to pull the 3 coils off in the oreillys parking lot unplug the icm walk inside and have it tested for free and go from there.............
I know they test them and I just called them to double check and make sure I wasnt loosing my mind either!
oh bring some money too if it is an ICM they are like 120 bucks IIRC.
yeah its 125 at my work (advance)...and rico...you said random :P
it was a random misfire but now number 3 misfire will advance do it or autozone bc we dont have a oreillys
