Thread: DTC P1689 need a bit help
Results 1 to 20 of 20
  1. #1 DTC P1689 need a bit help
    Wichita
    I thought I had this code taken care of. I cleaned the PCM & ABS connections on the wiring harness and the abs light went off. Then I cleared the p1689 code. Car ran great. Day later the code came back & it won't clear.
  2. #2 Re: DTC P1689 need a bit help
    What's that code?
  3. #3 Re: DTC P1689 need a bit help
    Wichita
    That's exactly what I said when it first popped up. It isn't in the Chilton manual so I had to Google it to find out what it was. Its a problem with PCM or PCM connection, ABS & the wiring between them. I thought the code was set by the loose connection at the ABS plug(Which was very dirty). I also cleaned up the connection plugs to the PCM. But the code came right back. However the ABS light did turn off after all the cleaning. I have checked out the code out at GearChatter & Ill admit I was confused on how tontroubleshoot the code. =\
    Is it a class 2 data error?
    Supossedly those lines have connectors in them that corrode and fail.
    Have you traced the entire circuit?
  5. #5 Re: DTC P1689 need a bit help
    Wichita
    Idk what a class 2 data error is & I haven't had time to trace all of those lines.
  6. #6 Re: DTC P1689 need a bit help
  7. #7 Re: DTC P1689 need a bit help
    Wichita
    ^^^No one there knew the answer either.
  8. #8 Re: DTC P1689 need a bit help
    Wichita
    Question. If my cruise control module is bad would that set the code p1689?
  9. #9 Re: DTC P1689 need a bit help
    Wichita
    Hmm, I don't have cruise control. I'm sure that's part of the DTC P1689. I checked the cruise control fuse and the wiring to cruise control & it all checks out. I haven't been able to find any bad wiring at all so far. Tommoro I'm going to try a different PCM and see if the code dissapears. After that idk what to do.
  10. #10 Re: DTC P1689 need a bit help
    Is your third brake light out by chance??
    Because that will make your cruise control not work.
  11. #11 Re: DTC P1689 need a bit help
    Wichita
    Idk suppose I could check.
  12. #12 Re: DTC P1689 need a bit help
    Can anyone copy and paste Gearchatter info here? I'm blind these days with things being blocked.
  13. #13 Re: DTC P1689 need a bit help
    Wichita
    Already found and read the gear chatter link you previously posted about this DTC. Thx.
  14. #14 Re: DTC P1689 need a bit help
    Wichita
    The problem was a broken fasteners where the wiring harness connects to the EBCM. I switched out the broken part from my old harness and problem solved. And no I don't have a bulb out in my third brake light. Stoll no cruise control.
  15. #15 Re: DTC P1689 need a bit help
    What's cruise doing? Cruise light even coming on like it's trying to engage?
  16. #16 Re: DTC P1689 need a bit help
    Wichita
    No nothing happens. Nothing at all =|
  17. #17 Re: DTC P1689 need a bit help
    Wichita
    I've been driving my car about 2 weeks now. Today I got a DTC P1585 which is cruise control inhibit. No wonder I don't have cruise control.
  18. #18 Re: DTC P1689 need a bit help
    Hmm but why ...lol Wish I could still see GC at work.
  19. #19 Re: DTC P1689 need a bit help
    Pennsylvania
    GM Service Manual:
    DTC P1558 set indicates that an improper voltage level has been detected on the signal circuit which controls the cruise control inhibit circuit.
    The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
    Step 1:
    Turn OFF the ignition.
    Disconnect the PCM harness connector.
    Turn ON the ignition, with the engine OFF.
    Using a DMM connected to a good ground, measure the voltage of the cruise control inhibit signal circuit. (B+... = "90V DC"?)
    1. If 90VDC, go to Step 2. If not, go to Step 3.
      Step 2:
      Disconnect the cruise control module.
      Probe the cruise control inhibit signal circuit with a test lamp that is connected to a good ground.
      If it doesn't light up, inspect for poor connections at the harness connector of the PCM. If it lights up, inspect for poor connections at the harness connector of the cruise control module.
      Step 3.
      Test the cruise control inhibit signal circuit for a open, high resistance or short to ground.
      If the condition is there, inspect for poor connections at the harness connector of the cruise control module. Else, clear the DTC.
  20. #20 Re: DTC P1689 need a bit help
    Wichita
    Thx!
  1. P1689 Code & Runs Rough Over Half Throttle
    By SUPERCHARGED3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 04:27 PM
