Thread: Coolant leak
Results 1 to 8 of 8
  1. #1 Coolant leak
    Northwest Missouri
    2004 pontiac grand prix....I've changed the coolant elbows (which were broken and leaking), changed the radiator hoses (which seemed ok) but i still have a small leak somewhere. still dripping.....slowly...but still dripping. any suggestions?
  2. #2 Re: Coolant leak
    what side of the car is it dripping from?
  3. #3 Re: Coolant leak
    Northwest Missouri
    it appears to be coming from under the belt area.
  4. #4 Re: Coolant leak
    Northwest Missouri
    the drips are dripping off of the oil pan....
    looks to be under the belt somewhere
  5. #5 Re: Coolant leak
    Could be the water pump
  6. #6 Re: Coolant leak
    Run your finger under the water pump pulley (engine off) and see if it comes back wet.
  7. #7 Re: Coolant leak
    GT Level Member tmackster's Avatar
    San Antonio, TX
    i am currnty having the same problem. most likely it it leaking under the water pump which causes the cooland to drip down under the belts near the oil pan. I am currnently in process of replacing the water pump for the 3rd time since July 2011
    '06 GP GT // Debadged // 20" Niche Venice rims w/toyo proxes4 tires, ram air inferno hood, front air dam, SE rear valance, black l.e.d. tail lights, CAI, MSD Ignition wires, Pioneer 6x9, & 10,000K HID headlights!!!
  8. #8 Re: Coolant leak
    well do it right lol
  1. Coolant Leak, But Where??
    By brandonl2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2011, 10:46 PM
  2. coolant leak
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-15-2011, 07:44 PM
  3. bad coolant leak
    By johnfolks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2011, 04:30 PM
  4. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  5. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
