Thread: Cold air blowing and overheating
Results 1 to 8 of 8
  1. #1 cold air
    Mar 2012
    hamilton
    hi my 03 is only blowing cold air i have replaced the thermostat any idea?
  2. #2 Re: cold air
    there are 2 hoses that come from behind your alternator and lead to the fire wall, warm up the car and see if these 2 hoses get hot. if not you may have air in your system or a clogged heater core, air is more likely. or your actuators took a dump on ya and are not turning the blend door.
    Ohio
    Did you bleed the cooling system?
  4. #4 Re: cold air
    Mar 2012
    hamilton
    How does one bleed the system
  5. #5 Cold air blowing and overheating
    Mar 2012
    hamilton
    My 03 grand prix gt was over heating the other day so I changed the thermostat it's still overheating and blowing cold air any ideas?
  6. #6 Re: Cold air blowing and overheating
  7. #7 Re: Cold air blowing and overheating
    Charles City, IA
    sounds like you have air in the system like stated above. Bleed the system and see if that helps.
    SMGPFC Two Nipple General
  8. #8 Re: cold air
    top of the t stat housing, there is a screw, warm up the car, and open it a few turns till a steady stream of coolant come out of the hole.
  1. 05 GP Air Conditioner Not blowing cold anymore
    By mpoynter31 in forum General Tech Discussion
    Last Post: 05-19-2012, 06:53 PM
  2. Overheat and blowing cold air
    By skibender in forum General Tech Discussion
    Last Post: 12-22-2010, 08:57 PM
  3. blowing air,,but not hot
    By mimi in forum General Tech Discussion
    Last Post: 12-14-2010, 02:40 AM
  4. Blowing cold air
    By tracker1925 in forum General Tech Discussion
    Last Post: 12-11-2010, 06:41 AM
  5. Heater blowing cold on drivers side
    By sophie in forum Introductions/Noob Questions
    Last Post: 11-03-2010, 08:00 PM
