Thread: Heater issue
Results 1 to 7 of 7
  1. #1 Heater issue
    Utah
    A few months ago it stopped moving between defrost, vent and floor and got stuck somewhere in the middle with air coming out all three. Yesterday it stopped coming out everywhere except a little out of the vents. Blower is working fine. I crawled around under the dash but didn't come across anything loose or disconnected.
    Where do I start to diagnose this?
    2001 Pontiac Grand Prix SE 3100 with dual climate control.
    Update: Chased a vacuum line based on something else I read. Found one that comes down over the passenger side strut and behind the battery that was broken. Started following it with my hand and it just shattered.
    Anyone have a vacuum diagram? I'm guessing this jumps into the wiring harness behind the battery and through the fire wall. It's broken far enough down I probably need to replace all the way through the harness. There's one that comes through the firerwall on the passenger side and then up to the side of the heater. Is it the same one?
  2. #2 Re: Heater issue
    Blend Door.
    The search button is at the top of the page in the black. Search blend door and that should lead you to a fix for it.
  3. #3 Re: Heater issue
    Utah
    It still blows hot and cold air as adjusted, just not through the right vents. Is that still a blend door issue?
  4. #4 Re: Heater issue
    Utah
    Pulled the blend door actuator and it moves the full distance when I adjust between hot and cold.
  5. #5 Re: Heater issue
    Mar 2012
    Orland Park
    Remove the battery and you should see the vacuum line is going to a vacuum ball, Go to your local auto part store and you can replace it with just a rubber piece. More then likely a little battery acid leaked out over the years and now has made the part very brittle or just eat thru it.
    Hope this helps
    The Boss Iceman6669's Avatar
    Jun 2011
    Had same problem with my 97 gtp.. It cracked in the same spot. All I can tell you is that it runs from the blower area through the firewall and then goes behind the battery.
    2011 F-150 Yote powered
  7. #7 Re: Heater issue
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    Can you take a quick picture of the area you found the leak? I may have the same issue and not sure which spot you found your leak at and want to check mine.
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  1. 97 heater issue
    By wib in forum General Grand Prix Discussion
    Last Post: 01-25-2012, 04:51 PM
  2. Heater fan in 97 GTP issue.
    By greenfiero1986 in forum General Tech Discussion
    Last Post: 10-16-2011, 02:51 PM
  3. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  4. Heater messed up (switches KPH so MPH) DIC won't turn on of heater.
    By Colossus in forum General Tech Discussion
    Last Post: 03-06-2011, 01:13 AM
  5. a/c and heater
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 03:22 PM
