Thread: stumble at idle
Results 1 to 7 of 7
  1. #1 stumble at idle
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i have a little stumble at idle it doesnt affect the RPMs at all but you can feel the car shake from inside and you you can see the engine shake slightly but more then it should. ive replaced the PCV valve, the air filter is 4 months old, the fuel filter and fuel pump are 5 months old, i dont know what else to change. its a 99 GTP with 170k miles on it
  2. #2 Re: stumble at idle
    clean the MAF with maf cleaner and the IAC valve
  3. #3 Re: stumble at idle
    SE Level Member sdogg201's Avatar
    Mar 2012
    Saginaw
    Don't forget the EGR
  4. #4 Re: stumble at idle
    Oct 2011
    Michigan
    i have no clue where the EGR is on my car would you mind posting a pic?
  5. #5 Re: stumble at idle
    St. Louis
  6. #6 Re: stumble at idle
    St. Louis
    When was the last time you changed the plugs and wires? Agree on cleaning the MAF using actual MAF cleaner, not carb or brake cleaner. You will need a security torx bit to remove it.
    When you replaced the PCV valve, did you reinstall the o-rings on it? If not, then it will cause a vac leak.
  7. #7 Re: stumble at idle
    Oct 2011
    Michigan
    plugs and wires are gonna get done next week i know to use MAF cleaner (isnt it a T20 torx bit?) and no there was no o ring on it when i pulled the old one out im assuming it got stuck in there still so i just put the new one in, its been a week ive probably drove it 250miles and there hasn't been a vacuum leak yet
  1. Stumble at 1500 RPM
    By fuzzbutt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-02-2011, 04:34 PM
  2. Hesitation and Stumble
    By Bill3256 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2010, 06:54 PM
  3. Engine Stumble
    By briggsracing23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-25-2009, 09:02 AM
  4. Rough Idle/Stumble after LIM Install
    By hesersypb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 08:27 AM
  5. Stumble at idle
    By lowdeuce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2008, 10:26 PM
