Thread: Solid service engine light?
Results 1 to 6 of 6
  1. #1 Solid service engine light?
    Kentucky
    I just put new plugs and wires on my car, (1997 grand prix gtp), The check engine light isnt on, but the service engine soon light is on and solid. Any suggestions? The other day I drove it, it was missing horribly and went WOT, check engine light came on and started flashing so I coasted home. So replaced plugs and wires, (went with Autolite 104, which is two heat ranges cooler), I also have a 3.5" pully. Any suggestions would be great guys. Don't wanna blow up my car.
  2. #2 Re: Solid service engine light?
    GT Level Member thegipper's Avatar
    grafton, wi
    I would get your car scanned soon. That should give you a better idea of whats going on. Let us know what codes you get and maybe we can help.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  3. #3 Re: Solid service engine light?
    Yoga city
    Is there just a 3.5 on that?
  4. #4 Re: Solid service engine light?
    If you didn't change one wire at a time, likely you have a couple crossed. No worries..just fix them.
  5. #5 Re: Solid service engine light?
    Kentucky
    Just on lunch break. Anyway, the wires are on correct, I know the cylinder numbers and made sure to map it out before changing the plugs. On that, yes, the only mods are 3.5" pulley and open come intake filter now with two heat degrees colder plugs and new wires. Like I said, the car isn't missing. Just the light is on, so I'm going to advance later and I'll get the code and post them up.
  6. #6 Re: Solid service engine light?
    Kentucky
    Ok guys. Got the code. I believe it was a P303, showed as cylinder three misfire. So, got them to clear the code and the light hasn't came back on yet, even after some throttle.
  1. Service Engine Soon Light On?
    By ljmonnin12 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2011, 12:04 AM
  2. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  3. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  4. service engine soon light =[
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2009, 10:06 AM
  5. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
