Thread: Vacuum Line Connections to sensors?
Results 1 to 3 of 3
  1. #1 Vacuum Line Connections to sensors?
    SE Level Member GTPGP98's Avatar
    NorthEast Kansas
    Okay, so this weekend I replaced the LIM gasket on my 04 GP Comp G. When I reconnected all of the electrical connections, I noticed that nothing connects to the vacuum port on one of the sensors that is located on the rear of the engine. The sensor on the right has the vacuum line connected to it from under the SC snout. The sensor on the left does not have a line connected to it. Does anyone know if a line is supposed to be connected to anything.
  2. #2 Re: Vacuum Line Connections to sensors?
    Those are both pressure sensors. One is hooked to the engine for manifold pressure the other is open to the air to determine current barometric pressure. It's correct for your year.
  3. #3 Re: Vacuum Line Connections to sensors?
    NorthEast Kansas
    Thanks Bill, just wanted to make that nothing was supposed to be connected to both of them.
  1. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  2. i need a vacuum line
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 04-20-2010, 09:07 PM
  3. Where is the vacuum line??
    By Bigbm80 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2009, 01:04 AM
  4. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  5. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
