Thread: clicking under dash
Results 1 to 4 of 4
  1. #1 clicking under dash
    SE Level Member k35gt's Avatar
    az
    Hey I was hoping you guys would have an answer on this one. It started about a month ago with the key not wanting to come out of the ignition. I started doing the tiny screwdriver in the steering column hole thing to get the key out, but just today I noticed all the power inside the car was out and the shifter wouldn't come out of park. I had to depress the interlock to get it into gear. The DIC, windows, radio, climate control dead. I climbed underneath the dash, removed the carpeted access cover and wiggled some things around and heard a clicking sound. I moved a block of wires just right and now everything is working again. Including the shifter. What do you guys think is bad under there? Brake switch ?
    Thanx...
  2. #2 Re: clicking under dash
    GTX Level Member blackflag's Avatar
    Virginia
    I feel like this is all i think about lately . Its probably the ignition switch. The "block of wires" that you wiggled is almost certainly the ignition harness, try to tighten the bolt in the center and see if that helps. Otherwise pay the $80 for a new switch and try to find some torx sockets. Good luck
  3. #3 Re: clicking under dash
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    It very well could be the ignition switch. Had the exact same issue with my grand am once. I never replaced it cuz it only happened like twice.
  4. #4 Re: clicking under dash
    SE Level Member k35gtx's Avatar
    AZ
    thanks guys, I'll look into it.
  1. Clicking and Sloshing behind dash!
    By kwakuzulu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-04-2012, 10:12 PM
  2. Box under dash loud clicking
    By darkhorizon in forum General Tech Discussion
    Last Post: 08-11-2011, 09:11 AM
  3. clicking sound under dash
    By CTKGP09 in forum General Tech Discussion
    Last Post: 07-15-2009, 01:04 PM
  4. clicking sound under dash
    Last Post: 06-23-2009, 08:05 PM
  5. Squeaking/clicking in dash, climate control?
    By jagamite in forum General Tech Discussion
    Last Post: 10-21-2008, 11:05 PM
