Thread: Vibration while accelerating
Results 1 to 8 of 8
  1. #1 Vibration while accelerating
    Louisiana
    I'm hoping someone can help me. My 2000 Grand Prix vibrates when I accelerate, any advice?
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Is it lowered at all? Mine has a vibration after I lowered it.
  3. #3 Re: Vibration while accelerating
    Sep 2011
    MI
    CV shaft or wheel balance.
  4. #4 Re: Vibration while accelerating
    CV shafts, maybe bad lower motor mounts, wheel balance.
  5. #5 Re: Vibration while accelerating
    Louisiana
    It isn't lowered at all. I read some other feeds on the net and paid a bit more attention. When I turn to the right it makes a sort of "banging" noise. Does this mean it's the CV joint? How can I check it to see if it's shot?
  6. #6 Re: Vibration while accelerating
    Louisiana
    I'm also fairly sure it's not the wheel balance. I had my tires rotated not too long ago. They checked the wheel bearings and also re-aligned it. Thanks for the help fellas.
  7. #7 Re: Vibration while accelerating
    Sep 2011
    MI
    CV shaft clicks when it is bad. Although it is possible its not that bad yet, just bad enough to cause a shake.
  8. #8 Re: Vibration while accelerating
    Louisiana
    Do you know a way I can check it, even if it's just visually, to see if it's actually the CV shaft or if it's another issue? I don't want to change out the shaft and joint only to find it was something else. Thanks!
  1. bad vibration while accelerating help please!!!
    By 01RedfireGT in forum Brakes/Suspension/Chassis
    Last Post: 09-29-2012, 08:54 PM
  2. Trouble with Accelerating
    By miker4792 in forum General Tech Discussion
    Last Post: 05-01-2011, 07:11 PM
  3. Miss While Accelerating
    By TDilley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2011, 11:52 PM
  4. GTP stalling while accelerating
    By SUGAR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 07:06 PM
  5. 02 GP Shakes upon accelerating
    By riddell87 in forum General Tech Discussion
    Last Post: 01-08-2010, 11:11 PM
