Im going to the track at the end of march and I want to try to set my tire psi at something for getting better traction. I have 17'' bullitts. Normal psi is 50 pounds. What range of psi should I try? Thanks guys
50 is what it says on the tire
A couple of my friends are getting together at beaver springs for a test and tune day. It will be my first time at a track. Should be fun
50 is the maximum tire pressure. You are suppose to inflate to the car manufactures recommendations. Check the sticker on driver door should be 30 to 35.
where at in pa?
I drop my pressure down to about 25. Makes a big difference.
50 psi your ballooning the tire and running on the center of the tread. It will wear out fast and the edges will still have good tread while the center will be bald.
